Vista - Stereo Mix and Sigmatel Audio and driver problem!
Old 05-02-2009   #1 (permalink)
Vista Home Premium 32bit
I have a Dell Inspiron 1525 with Windows Vista home premium 32bit installed on it. I downloaded the driver from the Dell website for the SIGMATEL STAC 92XX C-Major HD Audio and while it was installing I had it error. It says ExitError:Error= Device Object not present, restart the system and run setup again. I did so and it came up again. I have been trying to get Stereo Mix to show up in my recording devices so I can play music on my streams. I've done everything everyone has said. Show disabled devices and all that other good stuff and it doesn't show the sound card. Any help?
Stereo Mix / SigmaTel Drivers Installing Problem Sound & Audio
HEELP!!!!I HAVE A BIG SIGMATEL HD AUDIO DRIVER PROBLEM FOR VISTA Vista hardware & devices
SigmaTel High Definition Audio Driver Vista hardware & devices
SigmaTel audio driver installation - solved Vista hardware & devices
Sigmatel Audio Driver Vista hardware & devices
