Vista - Sound Icon in Taskbar Problem
Old 05-15-2009   #1 (permalink)
Vista Home Premium x64bit
When I go to "Taskbar and Start Menu Properties" and click on the "Notification Area" Tab I see that under "System Icons" that the only one I can check is the Clock; all the others are grayed out and I can't check them, however, I had a Sound Icon in my Taskbar previously that has for some odd reason simply disappeared, and since I can't check on it here, I can't seem to get it back in my Taskbar no matter where I look on the computer. How can I restore this option so that I have a Sound Icon in my Taskbar again, and are the other two features--Network and Power, a problem being that they too are grayed out?
Thanks for your help.
Old 05-15-2009   #2 (permalink)
Re: Sound Icon in Taskbar Problem
Hello Ccantare, and welcome to Vista Forums.
Sometimes a simple logoff and logon, or restarting the computer, can restore it for you. If not, then the tutorial below may be able to help you restore the icon.
Notification Area - System Icons
Old 05-15-2009   #3 (permalink)
Well, that's just great ...I chose the How to Reset and Clean the Notification Icons List in Vista option, ran it, and it did result in the Sound Icon reappearing in my Taskbar (although the Power Option is still grayed out under the "Notification Area" Tab), but it also took away the Taskbar's ability to hide inactive programs even though that's checked under the "Notification Area" Tab when in the Task and Start Menu Properties, and now I don't know how to get that to hide the inactive apps that I don't want to look at in the Taskbar. So now what should I do?
Old 05-15-2009   #4 (permalink)
By the way --in reference to that last reply, I did already try a rebooting to see if it will reactivate my Taskbar's ability to hide inactive applications there.
Old 05-15-2009   #5 (permalink)
This tutorial can help show you how to "hide when inactive" the icons again.
Notification Icons - Customize
Old 05-15-2009   #6 (permalink)
Quote  Quote: Originally Posted by Brink View Post
You misunderstand however --that's exactly the problem. All the Settings are correct: everything is set to "Hide when inactive," but the little left arrow that appears at bottom left in the Taskbar is gone, and nothing there will hide anymore. It basically got lost in the shuffle somehow when I reset everything the way I explained in my previous message.
Old 05-15-2009   #7 (permalink)
Never mind --the little arrow just reappeared on its own finally after about twenty minutes and hid all the inactive icons. I guess it needed some time to reset for whatever reason, which is weird, but thank you very much for you help -- I really do appreciate it.
Old 05-15-2009   #8 (permalink)
You're welcome CCantare. I'm happy to hear that it seems to have sorted itself out.
Old 06-20-2009   #9 (permalink)
vista home
thanks brink.. help me a lot
network icon taskbar icon not showing right Network & Sharing
Taskbar issues - missing power meter, network icon, and sound icon Vista General
Icon in the Taskbar? Vista General
taskbar icon Vista General
Sound Icon Missin in Taskbar Vista General
