| Vista Home Premium 32bit | How to play sound on TV? (solved) System: Vista Home Premium 32bit I am currently displaying my computer monitor on my TV. I am using HDMI output from my computer, and DVI input on my TV. The problem is that I cannot hear sound from the TV--it's still coming my from my computer speakers. My computer has a manual entitled "Important Audio Settings." It reads as follows: To set S/PDIF as your default audio playback device, follow these steps: 1. Select Start > Control Panel > Hardware and Sound > Sound icon. 2. Select the Playback tab. 3. Select S/PDIF Interface > Set Default, and then click OK. 4. Start QuickPlay (or restart it if it is already running), and you should hear audio on your device. My problem is that I do not have the option "S/PDIF Interface" in my Playback tab. I found a website that suggested right-clicking the white area and checking "show disabled devices," but it's still not showing up! How can I get this option to appear? Please help me. Thank you. EDIT: I received a response on a separate forum: Quote: Originally Posted by "vulpix" Quote: Originally Posted by "Minion4Hire" HDMI handles digital audio - DVI does not. There's your problem. You'll need to run a separate audio cable from your computer to your television (or home theatre) in order to get sound. Last edited by vulpix; 05-25-2009 at 05:27 PM.. |
| Play a sound when Copy | Vista General | |||
| Help! No sound when I play DVD's | Sound & Audio | |||
| How to play a sound for new mail? | Vista mail | |||
| computer doesn't play sound | Vista music pictures video | |||
| No sound when play DVD | Vista music pictures video | |||
