Vista Tutorial - detecting speakers still no sound
Old 06-14-2009   #1 (permalink)
vista 64 bit
hey all,
i recently just got vista and i've tried everything to get my speakers to work, i have updated drivers, made sure everythings enabled and asked different web sites.
the speakers are plugged into the back green hole, they work with my ipod and are being detected in control panel and device list.
the only thing i can think of is that the rear panel is not enabled some how, does anyone know how to enable it manually?
Old 06-14-2009   #2 (permalink)
Lost in my own World
Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86
Re: detecting speakers still no sound
you have to go into the bios and make sure that the onboard sound is enabled. i am asuming you are using the onboard sound if not than your sound card might not be vista compatable and you need a new one.
Old 06-14-2009   #3 (permalink)
vista 64 bit
how do i check that, i never had vista before and im scared to touch its bios
Old 06-15-2009   #4 (permalink)
vista 64 bit
sorry for double post, bios checked and its already enabled...
i have tried everything! this is insane.. if anyone knows a solution please post
Old 06-15-2009   #5 (permalink)
are the speakers powered or no. also check to see if the sound card is vista compatable.
http://www.microsoft.com/windows/com...?type=Hardware
Old 06-15-2009   #6 (permalink)
vista 64 bit
Speakers are plugged into an outlet and then into my computer.
Its an onboard soundcard. Realtek, like i said though when i go into the sound properties its showing the green bar beside it moving with the music, it has a green check, it doesnt make sense to me why its not working.
Old 06-15-2009   #7 (permalink)
have you tried to plug the speakers into different ports into the back of the card? maybe for some reason they don't go into the green plug.
Old 06-17-2009   #8 (permalink)
vista 64 bit
i know a fair amount about computers.. that was prob the first thing i've tried.
bump
Old 06-18-2009   #9 (permalink)
just making sure, i have done it before so that is why i asked.
is the driver up to date?
do you have a extra sound card to try?
Old 06-18-2009   #10 (permalink)
vista 64 bit
Well i figured it was a faulty driver so i just reinstalled it twice and its still not working. Did it in safe mode and didnt let vista do it..
uhm i never buy soundcards i just use the motherboard one, but its my brothers old computer and it worked for him.. so i really dunno
Usb speakers no sound comes out Sound & Audio
Speakers sound to "0", but there is still sounds from speakers Vista music pictures video
Vista 64-bit not detecting sound stuff? Vista hardware & devices
Low sound from speakers and no windows sound on new vista Vista hardware & devices
Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND Vista hardware & devices
