Vista - Microphone problems
Old 06-25-2009   #1 (permalink)
JLP
vista Home premiun 32bit
Microphone problems
Microphone problem: Recently when using Skype, my microphone is very scratchy when I am on wireless. I thought that it was the microphone. However, if I am on a hard wired connection, the microphone is fine. Also an external microphone works fine even when I am on the same wireless connection. I am in China, need to talk with family and could use some expert help.
I have a Toshiba Satellite laptop. My wife has the same computer and hers works fine on wireless. So I don’t feel that it is the wireless connection.
Old 06-26-2009   #2 (permalink)
Vista Ultimate X64, Windows 7 X64, XP Pro X64, Vista Home Premium X86
Re: Microphone problems
what sound card do you have?
or if you don't know what model # is you satellite?
you could just need a new updated driver for your sound card
Old 06-26-2009   #3 (permalink)
JLP
Thanks for your reply. I am really a newbie. My Satellite U305. I don't know how to get an update driver. Again thanks for your investment of time.
Old 06-27-2009   #4 (permalink)
U305-?????
need the rest and i can tell you exactly where to go to get the drivers.
Old 06-29-2009   #5 (permalink)
JLP
Satellite U305 S5077
Again, Thanks for your help.
JLP
Old 06-29-2009   #6 (permalink)
here you go
Model Content Page
Old 06-30-2009   #7 (permalink)
i think its vista 64
Hi i am also new to vista i talk on skype alot and my mic is constantly muting itself i keep having to go into control panel and having to unmute the mic how can i stop this from happening?what is cuasing it to mute?
Old 06-30-2009   #8 (permalink)
JLP
Fededrs
I did do the down load, but still have a problem with the microphone not being as clear as it should. I will be back in the States next month and perhaps can get it repaired then. They can replace the microphone here in Beijing, but I am afraid that since it is a part of the cover, it may not be easy to put it back together.
Again thanks. Went to school in Minneapolis, so I remember Maple Grove.
JLP
Old 06-30-2009   #9 (permalink)
ah a MN people, cool.
did it stop the auto muting or no?
Old 06-30-2009   #10 (permalink)
JLP
I never had problems with auto muting. That is someone else. JLP
Microphone Problems Sound & Audio
Microphone problems Vista General
Problems with Microphone Sound & Audio
All Problems in microphone Vista hardware & devices
Microphone problems with RC1 Vista hardware & devices
