Vista - Fatal1ty USB Gaming Headset HS-1000 issues
Old 07-03-2009   #1 (permalink)
vista home premium 32
So I followed the instructions and had uninstalled everything i installed with the disc it came with. I then downloaded the drivers from the creative website for windows 32bit and restarted.
Still no mic i checked the settings in the sound and nothing is muted and all bars are at high. I can hear everyone but no one can hear me.
Any help would be appreciated.
Old 07-04-2009   #2 (permalink)
Vista Ultimate x64, SP2
Re: Fatal1ty USB Gaming Headset HS-1000 issues
Hello BIGGD,
Have you configured the mic in the control panel ?.
Go to control panel and open Sound, there you will see a panel that looks like this, highlight the mic you are using and configure.
Also if you are using the mic in a game, you may need to configure the mic in the game sound options, make sure you dont need to press a key to transmit.
Hope some of this helps, Good luck and post your results.
Old 07-05-2009   #3 (permalink)
I tried to configure the mic but it wont pick up my voice for speech recognition.
The game I play is BF2 and I use a button to talk in game and also in Team speak.
Will this mic not work with push to talk gaming?
Old 07-05-2009   #4 (permalink)
Also did I do the process right? All I was suppose to do was plug in the usb and down load the firmware correct?
Old 07-06-2009   #5 (permalink)
Vista Ultimate SP2 x64 : Seven Ultimate x64
Uninstall the current drivers and try the latest ones:
Creative Worldwide Support > Fatal1ty USB Gaming Headset HS-1000
Quote:
This download supports the following devices only:
  • Creative Digital Wireless Gaming Headset HS-1200
  • Creative Fatal1ty® USB Gaming Headset HS-1000
  • Creative USB Gaming Headset HS-950
Fixes:
  • Resolves microphone related issues when using the above USB headsets with certain voice communication applications and games under Windows Vista® and Windows® XP. These include:
    • Low microphone volume level when used in voice communications applications such as Skype™ or TeamSpeak, and in certain PC games.
    • Audio distortion when microphone monitoring and X-Fi™ CMSS®-3D are enabled.
    • Restoring microphone default volume level.
    • Relative difference in volume level when USB Headset is plugged into different USB ports.
    • Installation issues that include Creative drivers not being installed when the USB Headset is plugged into another USB port, other than the port used during installation.
Also, in the recording properties>Custom , make sure microphone boost is enabled.
Old 07-06-2009   #6 (permalink)
All drivers and firmware are downloaded for the headset and restarted the computer. Still no microphone.
I saw a similar post in this area about vista thinking the headphones are speakers maybe that is why in properties I do not show the place to enable microphone boost nor do I have the ability to access HRTF.
Thanks
Old 07-07-2009   #7 (permalink)
Can you post a screenshot of the playback and recording tabs?
Old 07-07-2009   #8 (permalink)
[IMG]file:///C:/Users/DELGAD%7E1/AppData/Local/Temp/moz-screenshot-3.jpg[/IMG][IMG]file:///C:/Users/DELGAD%7E1/AppData/Local/Temp/moz-screenshot-4.jpg[/IMG]
[IMG]file:///C:/Users/DELGAD%7E1/AppData/Local/Temp/moz-screenshot-5.jpg[/IMG]
Old 07-07-2009   #9 (permalink)
hope this helps
Need help with Fatal1ty Headset Sound & Audio
Creative HS Fatal1ty Gaming Headset Mic Sound & Audio
Creative Fatal1ty Headset (Jacks, not USB) Microphone not working Sound & Audio
Creative Fatal1ty Gaming Headset - Microphone Problem Reply to this Post Post Reply Sound & Audio
The Best Gaming Headset? Gaming
