| Vista Home Premium 32bit | "The audio service is not running" Hello, I resently dowloaded several windows updates as well as scanned my harddrive for errors all at once, then the next time I restart my computer, my sound is completely gone with a red x on the speaker in the system tray. If I look at audio in services It is not started and when I try it says "error 1079 the account specified for this service is different from the account spesified for other servies running in the same process. Specs: Vista 32 bit |
| Vista Home Premium SP2 32bit, Windows7x32bit | Re: "The audio service is not running" Hello, I resently dowloaded several windows updates as well as scanned my harddrive for errors all at once, then the next time I restart my computer, my sound is completely gone with a red x on the speaker in the system tray. If I look at audio in services It is not started and when I try it says "error 1079 the account specified for this service is different from the account spesified for other servies running in the same process. Specs: Vista 32 bit Audio Error 1079 |
| "The Audio Service is not running" | Vista hardware & devices | |||
| Querying for "Auto" services that are not running via Get-Service | PowerShell | |||
| do not display "ERRORS" when running script without using $erroractionpreference = "SilentlyContinue" | PowerShell | |||
| "Extensible Authentication Protocol" service gives "The system cannot find the file specified" error | Vista networking & sharing | |||
| "De Service User Profile-service verhindert het aanmelden." | Vista account administration | |||
