| Vista Home Premium 32 bit | volume keys not working I just bought this Laptop for the wife. HP G60-445DX Notebook PC. The volume keys don't work. Does any one have a suggestion or a fix for this problem. It's brand spanking new with all updates. I contacted HP and they told me that I have to press the fn key and the up/down keys at the same time to activate them. It doesn't work. If I hold down the fn key and press either up/down key then they work. Big pain in the butt, can some one help. thanks. |
| Vista 32 win 7 7600 32 bit | Re: volume keys not working I just bought this Laptop for the wife. HP G60-445DX Notebook PC. The volume keys don't work. Does any one have a suggestion or a fix for this problem. It's brand spanking new with all updates. I contacted HP and they told me that I have to press the fn key and the up/down keys at the same time to activate them. It doesn't work. If I hold down the fn key and press either up/down key then they work. Big pain in the butt, can some one help. thanks. Ken |
| Vista Home Premium 32bit OS / Sp2 | Re: volume keys not working Hey ZZ . I think bass is talking about "Sound" volume key .... Right click on "Speaker" ... |
| Windows 7 Ultimate x64 | Re: volume keys not working That seems fine. I have to hold down fn and press f3 or f4 to decrease or increase the volume. You can download a macro recoder and make your own macro if it annoys you that much. |
| Esc and Tab keys stop working | Virtual PC | |||
| Volume Keys on Wireless Natural Kbrd no workie | Vista hardware & devices | |||
| keys & SHIFT keys not working properly in Vista Home Premium | Vista General | |||
| Fn keys no longer working | Vista General | |||
| Family Duscount Keys not working | Vista General | |||
