| x64 | Sound Driver intermittenly detects HDMI Sorry for yet another thread on no sound output for HDMI, but I am getting near wits end. My IDT High Definition CODEC driver seems to just stop recognizing the HDMI audio output on its own. Usually I just reinstall the driver downloaded from the OEM (HP) and it works, but this time it isn't working. Even when the IDT HD Sound menu does show the HDMI, now I can't enable it. I can click to enable, but it doesn't hold. Anybody have an idea? PC Specs: HP Pavilion Dv3t 4G ram Intel 2.13GHZ dual core 64 bit Vista Home Premium Thanks in advance for any ideas... |
| vista home premium | Re: Sound Driver intermittenly detects HDMI can you install the from an older driver? |
| x64 | Re: Sound Driver intermittenly detects HDMI I'll give that a try. Not sure where to find older version. I'll try IDT site or HP site I guess. |
| No sound through HDMI, but also cant mute | Sound & Audio | |||
| HDMI to amp no sound | Sound & Audio | |||
| Optical or HDMI to amp for sound? | Sound & Audio | |||
| Vista HP 64 detects sound card but wont play thro speakers | Sound & Audio | |||
| no sound through hdmi?? | Sound & Audio | |||
