| Vista Business Pro 6.0, 32bit | Microphone won't work with Vista I have a desktop computer. Windows Vista Business Pro 2007 (6.0). 18 months ago, a friend from church who builds and fixes computers on the side; put the Vista OS in this tower by Centurion. I have never been inside a pc so do not know anything about the inside. It has: 2 gig RAM, DVD/CD-Rom drive: Memorez DVD16+/-DL4RWnD2ATA Device; IED Channel, VIA Bus Master IDE Controller - 0571; Vinyl AC'97 Codec Combo Driver (WMD); Mainboard-MSI PT 880 Neo-FSR (Ms-7043); Chipset: VIA PT880. I have contacted the VIA company with no replies about the soundcard. I have tried both a desktop and headset w/mic and neither works. Someone told me it is hard to get a microphone to work with Vista. Another said the guy put a new OS onto old hardware. I am on SS, so cannot afford another pc. Do I need a new soundcard, or try a usb mic? PLease advise. I have gone into sound in control panel and unmuted the mic. It says in there Line-in not available. Jack not available. Yet, mic is working. What does this mean? Thanks. |
| Vista 32 win 7 7600 32 bit | Re: Microphone won't work with Vista I have a desktop computer. Windows Vista Business Pro 2007 (6.0). 18 months ago, a friend from church who builds and fixes computers on the side; put the Vista OS in this tower by Centurion. I have never been inside a pc so do not know anything about the inside. It has: 2 gig RAM, DVD/CD-Rom drive: Memorez DVD16+/-DL4RWnD2ATA Device; IED Channel, VIA Bus Master IDE Controller - 0571; Vinyl AC'97 Codec Combo Driver (WMD); Mainboard-MSI PT 880 Neo-FSR (Ms-7043); Chipset: VIA PT880. I have contacted the VIA company with no replies about the soundcard. I have tried both a desktop and headset w/mic and neither works. Someone told me it is hard to get a microphone to work with Vista. Another said the guy put a new OS onto old hardware. I am on SS, so cannot afford another pc. Do I need a new soundcard, or try a usb mic? PLease advise. I have gone into sound in control panel and unmuted the mic. It says in there Line-in not available. Jack not available. Yet, mic is working. What does this mean? Thanks. Can you go to start>search> type device manager> look for audio device. Is it listed there? does it have a yellow triangle on top? is there any "unknown devices" that have a yellow triangle on them? ken |
| Vista Business Pro 6.0, 32bit | Re: Microphone won't work with Vista No, the mic doesn't work. Even though there is a green check mark under sound for the mic. I typed device manager from start-search and device manager was in the list, as was soundcard. No audio device was listed, however. I went into device manager, and under sound and media, my sound card is listed, but no yellow triangles are there. |
| Vista 32 win 7 7600 32 bit | Re: Microphone won't work with Vista songbird well that is actually good news. with the driver installed correctly it has to b e configuration. couldl you use the snipping tool to take a snapshot of your sound control panel and upload it to us? thanks ken |
| Vista Business Pro 6.0, 32bit | Re: Microphone won't work with Vista What is the snipping tool? I have only been on a computer since 2003 and have learned by myself here. Thanks. |
| | #6 (permalink) |
| Vista 32 win 7 7600 32 bit | Re: Microphone won't work with Vista you get to it by going to start>search>type snipping tool thats it hope this helps Ken |
| | #7 (permalink) |
| Vista Business Pro 6.0, 32bit | Re: Microphone won't work with Vista I did the snipping tool and took two shots and saved them in My Pictures. Then, they were not found! Guess will try again. I looked evereywhere and even did a search. |
| | #8 (permalink) |
| Vista 32 win 7 7600 32 bit | Re: Microphone won't work with Vista In order to upload the snips you need to use the attachment icon (shaped like a paperclip) in the reply form ken |
| | #9 (permalink) |
| Vista Home Premium 64 bit (SP2) | Re: Microphone won't work with Vista Hi, I'm having a similar problem. My headphones work fine, but the mic isn't picking up any sound. I'm on Vista Home Premium 64bit, with an SB Audigy. In the 'Sound' box, my mic has a green tick and is apparently 'working'. Help! |
| | #10 (permalink) |
| Vista Business Pro 6.0, 32bit | Re: Microphone won't work with Vista I know how to add an attachment. I did the snipping tool, saved and named both shots, and put them in my pictures folder. They are not there or anywhere on here even searched C drive! That is what I am saying. I can't get it to work. Sorry. |
| Logitech Microphone VISTA 64BIT dont work!! help | Sound & Audio | |||
| RE: Microphone does not work - Vista Home Premium | Vista General | |||
| Sound recorder doesn't work with microphone in Vista | Vista General | |||
| Front panel microphone and headphone doesn't work Win Vista | Vista hardware & devices | |||
