| | #11 (permalink) |
| Vista Home Premium 32 bit | Re: Clicking noise from speakers I checked the sound each one made (Default) and the Start Navigation had a click just as I described. I just changed that to None and will see if that does the trick. I'll report back. Thanks. |
| Using External Speakers and Laptop Speakers | Sound & Audio | |||
| external speakers not working/pc has internal speakers | Sound & Audio | |||
| Hard drive making noise thru speakers | General Discussion | |||
| USB speakers wiped out my built in speakers | Vista hardware & devices | |||
| anoying noise in speakers | Vista hardware & devices | |||
