MicBoost
Varks
MicBoost doesn't seem to exist anywhere. I've searched for it in regedit and turned up nothing, and I can't get the custom tab in properties to come up.
The sound quality is also terrible, not sure how to go about improving it. Theres a constant static in the background when I speak, always. I'm plenty comprehensible there's just that annoying sound in my background over ventrilo and I'm aiming to kill that if possible, could just be the mic. (Its a logitech)
My computer is setup with two analog ports, one in the front and one in the back. Sometime back I plugged the mic into the front and have since been unable to get it to work in the rear. I either get no sound, or voice doesn't work. I've tried disconnecting the front completely, and a number of other things to no avail. This isn't so much the real problem though, mostly interested in getting micboost working and perhaps improving quality with any know how you guys provide. Or it could be the problem, that the front port is messed up somehow.
I attached my comp's Dxdiag, dunno if it'll help.
  • DxDiag.txt
It sounds like the mic connector on the front didn't disengage properly. The prongs on the connector should be in one position with a mic jack plugged in, and in another with no mic plugged in. Looks like it is stuck in the 'mic in place' position. I have seen this problem in steroes, but it does show up in computers from time to time.
You may have to get the mic connector replaced.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
Shouldn't removing it completely from the computer fix this? It connects to the sound card and runs wires to the front port, I removed all of that bit and still had no luck with it. Anything I missed?
It should fix it. But it looks like the inside of the mic connector in the computer isn't working properly.
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
