Imperfect1
I have a very low level of sound volume, and can't seem to raise it, no matter what I try to configure in either the Sound section or the IDT Audio section.
I have an HP dv5t, and am running Vista 64 bit. The system has IDT High Definition Audio (version 1.0.6225.0; and IDT Driver - version 6.10.6225.0), and NVIDIA High Definition Audio (version 1.0.0.0.59 - Driver files version 6.0.6001.18000 longhorn_rtm.080118-1840). I also have Bluetooth Stereo Audio on my system, although I've never used it. Device Manager says all 3 are working properly.
When I plug in headphones I get a much higher amount of sound volume -- although it may be misleading because the sound is, of course, directly in one's ears. I have tried to set all of the customizations that I can think of, but really could use some suggestions.
Thanks very much in advance!
- HP Pavillion dv5t (Gen. 1)
- Intel(R) Core(TM)2 Duo Processor T9400 (2.53 GHz)
- 4GB DDR2 System Memory (2 Dimm)
- Graphics Card(s)
- 512 MB NVIDIA GeForce 9600M GT
- 15.4" diagonal WSXGA+ High-Definition HP BrightView Widescreen Display
- 1680 x 1050
- 320GB 5400RPM SATA Hard Drive with HP ProtectSmart Hard Drive Protection
- built in - HP
- built in - Synaptics TouchPad V6.5 on PS/2 Port
- max
- Other Info
- ~ Intel Next-Gen Wireless-N Mini-card w/Bluetooth ~ Blu-Ray ROM DVD+/-R/RW ~ Integ. HDTV Hybrid Tuner ~ 12 Cell Battery ~ MS Office (Home Premium) 2007 ~
