Changing default Sound Device
  1. #1
    Newbie
    Vista Home 32bit
    Local Time: 10:54 PM
    Is there any possibility of changing the sound device programatically in Windows 7?
    Or atleast to make the device as the default sound device during installation?
    In Vista, I could use SetupPreferredAudioDevice key in INF file to make it as default at the time of installation, but I could see that this key is no more valid in Windows 7. Is there any alternative for this?
  2. #2
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    Vista Home Premium x64 SP2
    Local Time: 11:24 AM
    usa us minnesota
    Re: Changing default Sound Device
    Note that you shouldve asked on this website instead - Windows 7 Forums
    But, to answer your question, Vista and Windows 7 have the option to allow any program to use a particular device automatically. Even when installing any new program.
    sdfg.jpg (Set default device here, unless you only have one input/output deviced enabled)
  3. #3
    Newbie
    Vista Home 32bit
      Thread Starter
    I am really sorry for posting it here.
    But here we are doing that manually, right?'
    I am having an application which uses a virtual audio driver and I want that device to be the default sound device when the application starts. So it will be really helpful if can change it programatically. Is that possible in vista and win 7?
  4. #4
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    usa us minnesota
    Quote Originally Posted by arunsankar View Post
    By having those box's checked (they are already on default), the program should automatically use THAT default sound device, unless there is an unsupported feature with the program and sound device.
  5. #5
    Newbie
    Vista Home 32bit
      Thread Starter
    These options are checked in my system and I can also set a device as the default one manually. But I am unable to set this as programatically.
  6. #6
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    usa us minnesota
    Any program that uses sound, AUTOMATICALLY uses the default sound device that you choose in that area.
    If you have installed a new sound device (soundcard), you mainly want to just use the hardware's set of sound device's and disable the onboard sound in your BIOS.
    Usually, if the program has a VOIP function (Games for Windows - LIVE, MSN messenger, Steam-based games) in it or either someone uses a DVD codec application (PowerDVD, Nero, Etc.), most of the time they can set what device for THAT program to use when playing/using that program (there is usually an options menu with that function there).
    If this still doesnt answer your question, exactly what are you trying to do with a sound device regarding Windows 7?
  7. #7
    Newbie
    Vista Home 32bit
      Thread Starter
    As I mentioned earlier, I have a virtual audio driver which captures the data and do some processing on audio samples and then routes it to one of the playback sound device. For this, I need this virtual driver to be the default sound device when I am running my application. But I don't want the user to change the sound device, instead I want to insert some code in my application so as to change the sound device. This is very much possible in XP. But it is not supported in Vista and Windows7. In Vista, I could use SetupPreferredAudioDevice key in INF file to make it as default at the time of installation, but I could see that this key is no more valid in Windows 7. So I want to know whether there is any alternative solution for this?
  8. #8
    MDA400's Avatar
    Nvidia and Intel
    Bloomington, MN
    usa us minnesota
    Forgive me lol. your programming an app. right? Then you'd have to look that up somewhere else because i have no familiarity with that. Sorry.
  9. #9
    Newbie
    Vista Home 32bit
      Thread Starter
    Its ok MDA400.
    Thanks a lot for your kind attention...
Changing default Sound Device problems?
Problem with sound (Set default device) exact Gaming 10 10 Sep 2009
Default Sound Device Issue David4321 Vista hardware & devices 0 15 Aug 2009
Default Sound Device Issue David4321 Sound & Audio 0 15 Aug 2009
How to prevent default audio device from changing to SRS? taylormah Sound & Audio 6 28 Apr 2009
Default Sound Playback Device Changes itself Geo Vista hardware & devices 0 07 Sep 2007
