Sound Icon gone.......
  1. #1
    garaboldi's Avatar
    70-290
    Morgantown Pa
    Vista Home Basic 32x SP1
    Local Time: 09:04 PM
    usa us pennsylvania
    Lower Right hand corner where the time and battery are displayed no longer has the typical "speaker" icon for sound. I can still access it threw the control panel so it is working. Anyone know how I can get the icon back on the lower right hand corner where it use to be?
    Ryan
  2. #2
    Brink's Avatar
    Administrator
    Texas, USA
    64-bit Vista Ultimate SP2, Windows 7 Ultimate SP1, Windows 8 Enterprise
    Local Time: 08:04 PM
    usa us texas
    Re: Sound Icon gone.......
    Hello Ryan,
    Double check using the tutorial below to see if you can check the "Volume" option to have it back. If not, you will also see other options in the tutorial to see if you can get it back.
    Notification Area - System Icons
  3. #3
    Imperfect1's Avatar
    Senior Member
    Los Angeles, California + Milwaukee, Wisconsin
    Vista Home Premium x64 (SP2)
    Local Time: 07:04 PM
    usa
    I have this problem every now and then, but the icon comes back after I shut down and reboot. Have you tried that?
Sound Icon gone....... problems?
sound icon goldpony Vista General 0 10 Dec 2009
SOUND ICON MISSING PAUL Vista General 2 04 Nov 2009
Taskbar issues - missing power meter, network icon, and sound icon The Shadow Vista General 9 27 Apr 2009
sound icon abby963727 Vista General 2 15 Jun 2008
Sound recorder icon Ria Vista performance & maintenance 0 29 Sep 2007
