Plug and play/ blank device mgr/ no sound
  1. #1
    Newbie
    VISTA HOME PREMIUM 32BIT
    Local Time: 04:37 AM
    Hello,
    7 days after my Dell warranty expired my XPS 410 w/ Vista HP 32 bit has a big issue.
    I am a novice but I have gathered that my plug and play is the issue. In services.msc, I cannot start plug and play, therefore cannot start windows audio service. It says plug and play service started and stopped. some services stop automatically if not in use. For windows audio i get error code 1059, circular dependency.
    When I open device manager it is blank. I have absolutely no idea what is going on, this is all of a sudden. Also causing windows explorer to crash. I have done system restore and it still is not fixed, restore will not complete.
    Any assistance is appreciated.
  2. #2
    Banned
    Phnom Penh
    Windows Vista Home Premium x32 Service Pack 2
    Local Time: 02:07 PM
    cambodia
    Re: Plug and play/ blank device mgr/ no sound
    So, it's a software problem. Use System Restore to roll back the PC to a time when the sound worked. Your personal problems won't be touched. Try reinstalling the sound drivers if that doesn't work. That'll probably fix everything.
  3. #3
    xp, vista,w2k
    Local Time: 02:37 AM
    check that these services are set to automatic start (not delayed)
    dcom server process launcher
    remote procedure call
    windows audio
    circular dependencey errors are often caused by services not starting or configured correctly, has there any changes to the o/s recently? new hardware fitted or failed. administrator account changed or removed?
    its also worth trying scanning for faults
    system file check ( sfc.exe /scannow)
    drive data errors (my computer/localdrive/properties/tools, check for errors)
    and the drives hardware health, use the manufacterers diagnostic app.
  4. #4
    Junior Member
    Vista x32 SP2
    Local Time: 08:37 AM
    I have this exact same problem. EXACT!
    Please someone help!
  5. #5
    Junior Member
    Vista x32 SP2
    The only changes to the software I made was plugging in a Logicam webcam (a really old one where I cant find the drivers for) which was detected fine and worked fine.
    I saw on a nonther forum that this may have been the cause of the problem and that the soultion was to uninstall the logicam driver. But I dont have one installed!??
  6. #6
    Junior Member
    Vista x32 SP2
    Also, Plug and Play is not listed in 'Administration Tools' - 'Services' so I cannot set it to automatic. Ahhhh!!
  7. #7
    Junior Member
    Vista x32 SP2
    Please can someone offer some insight into this problem??
    I simply cannot afford to put my PC into a shop and I need it for work.
    I'm an absolute novice with PCs and really require some help.
  8. #8
    Junior Member
    Vista x32 SP2
    For the love of god someone help!
Plug and play/ blank device mgr/ no sound problems?
Vista doesn't plug and play device driver's not found E Vista hardware & devices 3 16 Dec 2007
plug and play George Vista hardware & devices 0 02 May 2007
Plug and Play George Vista General 0 02 May 2007
how do i find the plug-n-play ID for a Device? Steven Wabik Vista hardware & devices 0 30 Sep 2006
how do i find the plug-n-play ID for a Device? Steven Wabik Vista installation & setup 0 30 Sep 2006
