Realtek HD Audio Manager Missing
  1.    07 May 2010 #1
    Vista Home Premium 32 bit
    Local Time: 23:14
    Hi
    I don't know if you will be able to help me but I will try and explain my problem. Please bear with me and I will try and put it as clearly as I can.
    I have a Fujitsu Siemens Amilo Pi1505 laptop with Windows Vista 32 bit home premium installed.
    When I got the laptop there was an icon in the system tray near to the clock which when you clicked on it opened up a nice looking graphic from which you could alter the realtek sound settings and choose things such as concert speech room etc. It had graphics depicting speakers and other things.
    I have now found an image of it on the web at : http://www.mydigitallife.info/wp-con...k-hd-audio.jpg
    It is/was called the Realtek HD Audio Manager
    That has now completely disappeared and I cannot seem to get it back or find it anywhere on my computer.
    It made making adjustments to the sound settings so much easier and I miss not having it.
    Is there anyway to restore it back so that I can alter my sound settings more easily
    I do hope I am making sense with this??
    Look forward to hearing from you
  2.    08 May 2010 #2
    Vista Home Premium 64 bit
    Local Time: 18:14
    Re: Realtek HD Audio Manager Missing
    Hi well if it is still on the system you will see it in the control panel. If not check in add remove programs to see if it's there, if it is there maybe it got disabled from startup. Go to start where is says start search type in msconfig and push enter, next choose the startup tab do you see it listed there if so and there is no check mark beside it put a check mark and reboot it will then start.
  3.    08 May 2010 #3
    Local Time: 23:14
      Thread Starter
    Hi
    No its definitely not there anymore I think somehow I must have deleted it.
    What are my options now. I only want the manager not the programme as that is clearly still there
    Mike
  4.    08 May 2010 #4
    Local Time: 23:14
      Thread Starter
    Hang on Hammey - appologies it is there in the control pannel -well done thanks for that.
    Now I will try and get it in a position to use again
    I may be back in a min for more advice lol
  5.    08 May 2010 #5
    Metro Toronto, ON, Canada
    Vista Home Premium 32-bit.
    Local Time: 18:14
    canada ca ontario
    To get the Audio manager back, download the Audio Driver from your computer manufacterer for your specific model.
    You could also run "msconfig" to see if "HD Audio Control Panel", is in the startup list and enabled.
    Only download from realtek's website, as a last resort.
  6.    08 May 2010 #6
    Local Time: 23:14
      Thread Starter
    Ok Its definitely still on the computer and listed in control pannel
    How do I get it to load up and sit in the system tray from now on.
    Its not an option in the start up tab that Hammy mentions
  7.    08 May 2010 #7
    Local Time: 18:14
    canada ca ontario
    Go to Vista's control panel, and launch the "Realtek HD Audio Manager".
    Then click the " i " in the bottom right-hand side (i = info, or about), and click the circle that says, "Display icon in notification area".
    Attached Thumbnails Attached Thumbnails -realtek-hd-audio-manager-jpg
  8.    08 May 2010 #8
    Local Time: 23:14
      Thread Starter
    Hi
    Thanks a lot that worked
    Thanks for all the replies
    Have been without that little widget for more than 2 years so real pleased to have it back
    Thanks
    Mike
Realtek HD Audio Manager missing from Device Manager & Advanced Tab missing from BIOS
I have a HP Pavilion dv6707us Entertainment Notebook PC. I was using Home Premium 32 bit Vista but I did a clean installation with Home Premium 64...
Sound & Audio
Missing Realtek HD Audio Manager in system tray
Hello, I recently bought a Toshiba A300D laptop (64 bit, home premium) and it had the Realtek audio driver installed to have the audio output through...
Sound & Audio
32 bit vista no sound realtek hd audio manager missing
Hi. I have a problem with 32 bit Vista. I have no sound! The machine is a Dell XPS 435 MT and comes shipped with 64bit windows which is...
Sound & Audio
Realtek Audio Manager (Yes Again)
I have spent a lot of time browsing around the threads here. I have found a lot of very similar threads, but not what I am looking for. If there is...
Sound & Audio
Hi All, Hopefully you can help me, I have updated my Audio drivers and now i no longer have the HD Audio manager application I have searched...
Sound & Audio
realtek HD audio manager
couple of problems seem to be occuring with this programme. firstly the front mic port is highlighted pink even when no mic is connected. is this...
Sound & Audio
What is Realtek HD Audio Manager? After I installed more memory, when I clicked on the speaker icon in the lower right it said nothing was...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
