Hi Im trying to find out if my windows vista pc has a build-in microphone. If so how do i acess it and return it on. Any answer will be a big help!! Thank You!:D
Conexant 20561 SmartAudio HD
15 inch
1x 180GB Intel 530 series SSD
1 x 120GB Hitachi 5400rmp
Medium for New Zealand
Only ever used a laptop.
Also use USB Freeview TV Card
Lenovo Docking Station
External Speakers
Other bits a pieces as needed
Please note Windows Vista is an operating system, and it falls under the category of software. A microphone is a piece of Hardware.
You should be able to find out if your PC has a microphone by checking the specifications. This can be found either with the literature that came with your PC, on the side of box, or on the PC's manufacturer website.
If your computer is a laptop or netbook, then it will have a built-in microphone. If not, then you will need an external microphone to plug in (this will also work with a laptop/netbook as well).
ViewSonic VA1912w Widescreen
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
