The sound entry in control panel (your right side picture) right click on it and is there an entry in properties for ATAPI Internal Jack.
I see you have a Realtek Sound system, Is there a Realtek entry in the control panel? If so when you hover your mouse over the plug looking icons do you get mic,headphones,show up
Is the default format set to 24Bit 48000Hz
