Audio gone no sound
I was in the middle of playing world of warcraft when I noticed my sound just turned off.
Checked my volume everything is turned up to max
I check driver its up to date and according to properties working properly
I have gone through device manager and drivers where uninstalled and then the laptop was rebooted. Drivers were reinstalled but no change in sound.
Even when I plug headsets into the jacks I get no sound at all. Nothing has been muted sound is turned up to max.
I have read some where to go into an entertainment folder and look for volume control. So I go through ALL PROGRAMS-ACCESSORIES- and find no such folder called entertainment. I did a system search for the volume control and there was no hits..
What do I do from here?
    Acer Aspire 4530
    AMD Athlon 64 x2 Dual core
    2GB DDR2
    Nvidia GeForce 9100m G
    120 gb factory installed
Start,Control Panel,Sound,playback.
What does it say there.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Suggestions :
1. Microsoft Fix It application :
Diagnose and repair sound playback problems automatically
2. Right click on Volume icon in system tray > Playback Devices > click the Speaker which has the word " working " under it > Properties > under Device Usage, make sure it says Enable > Levels > make sure the slider is up to the right > OK
  • Other Info
    WLM 2011
    IE9 beta
downloaded that fix it program it found nothing and said it could not fix the problem :sarc:
Still no sound..
Any other suggestions?
    Acer Aspire 4530
    2GB DDR2
Still no sound..
Suggestion #2. Try it yet ?
yes, no change
Do a system restore. Pick a " good " date when you did have sound as your restore point.
In case you need the " how-to " :
Start button > search box, type system restore > press Enter key > uac prompt > click Choose a different restore point > Next > select the " good " date as your restore point, click it > Next > Finish
Sit back and wait. The machine will re-start when it is done.
  • Other Info
    WLM 2011
    IE9 beta
yes, no change
there was no restore points available when the audio was working :eek::cry:
    Acer Aspire 4530
    2GB DDR2
yes, no change
By the way you wrote in your original post, I thought it was a " just yesterday " issue.
How long ago was that ?
Edit :
Anyone playing World Of Warcraft could not have stopped playing it for more than 2 days. :-).
So, how long ago ?
  • Other Info
    WLM 2011
    IE9 beta
unfortunately its been about a month maybe alittle more that I have been with out audio..today was the first day I was able to attempt any sort of trouble shooting
    Acer Aspire 4530
    2GB DDR2
In that case, I must bow out.
I can't solve your problem.
  • Other Info
    WLM 2011
    IE9 beta
In Device Manager, do you have any yellow warning triangles adjacent to any of the categories, specifically the one highlighted below?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
nope...i'm really beginning to think the speakers themselves have died. But would that affect the headsets? Because i can't hear anything even with the headsets?
    Acer Aspire 4530
    2GB DDR2
Try a system file check it won't hurt.
Go to start,all programs,accessories,command prompt. Right click and Run as administrator.
Type SFC /Scannow
Note the space after C
If it finds anything run it again with a reboot between runs.
See if it finds anything it can fix.
    LENOVO 64734VM
    15 inch
    External Speakers
