Headset setting checklist?
A
Advice Pro
I'm having issues with my Vista doesn't recognize my speech at all. I want to thoroughly diagnose the issue, so please check my setting:
The 1st 3 attachments pop-up when I insert the headset, 1st sound output then sound input, into the audio jacks on the front of my PC.
The last 2 attachments are 2 things to check concerning the headset.
I've not check the audio drivers, to update if necessary. Please tell me if you know how to check that as well as any other things to check that you can think of.
First thing to notice is the mic is selected to a USB device not the Realtek one, is that correct?
Did you get a driver/ installation disk with your headset & mic?
Have you used/ installed the drivers for the USB mic? If that is the device showing with no drivers.
If I am assuming incorrectly, please advise me further.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Lottiemansion, my headset usb, it's anolog. There are no drivers or installation for the headset.
    40 Meg
