For me... when I'm at the near end of my song it just stops for two seconds and makes a crackling sound. What is this? What does it mean? How can I stop it from happening?
Welcome
The fist step is to make sure that your audio driver is up to date and not corrupted
Go to search
type device manager
In device manger look for any yellow markers
Then make sure audio driver is up to date.
I can only give what I know. To me it sounds like the card or driver. Update audio drivers. Look at graphics driver too.
Card may need replacing.
Any other symptoms or problems?
Did you change anything when this started?
