My system tray shows a volume control with a red X on it and although my device manager says the device is working properly, no sounds come out, and the volume mixer complains that "no audio device is installed" ; windows vista, 32 bit, Packard Bell laptop 4 years old. I have tried all the "usual" stuff like Device Manager and so on........
The usual stuff - enable/disable, uninstall/re-install, also system restore etc
Nothing of the above works....
Also, since the problem with the sound device started I canīt upgrade to SP2 or install updates for vista.
I have two identical laptops and I have this problem with 1 of them. So...
