JaredInsanity
Specs:
HP TouchSmart IQ506
Windows Vista Home Premium 64-bit
About a year ago, my TouchSmart hard drive crashed, so I took it to FutureShop and had it replaced. I was able to put all of my data back on, because it was backed up, but i noticed that my audio did not work correctly. All they had done was put Vista back on to it, so I didn't have the TouchSmart software or Realtek HD Audio Manager like I used to.
Anyways, the main problem is that once I unplug my headphones, I cant use them again until I restart the program I'm using. For example, say I have my headphones plugged in and I start Firefox. The sound will play through the headphones just fine, and if I unplug them the sound will play through the speakers just fine, but when I plug them back in, the sound will continue to play through the speakers. The only way to get the headphones to work again is to close Firefox and reopen it with the headphones already plugged in.
What may be causing this and how can I fix it?
HP TouchSmart IQ506
- HP TouchSmart IQ506
- Intel Core 2 Duo
- 4.00 GB
- Graphics Card(s)
- NVIDIA GeForce 9300M GS
- AVerMedia A327 Mini-Card Hybrid Analog/ATSC
- 1680 x 1050
- 454.31 GB
- 54.0 Mbps
