No sound on any jack
  1. #1
    vista home premium
    Local Time: 11:17 AM
    Hi, today i tried to set up a surround sound system on my PC....when it didn't work i just put it back to using the speakers on my monitor. However now i have no sound at all coming from the speakers.
    No sound through the headphone socket either.
    I am not a computer expert but have basic knowledge, have checked device profiles and found Realtek Digital Output entry, along side this it shows a bar of lights which bounce up and down in line with the song i had playing. So all seems to be running ok but no sound. Is this the right device though? When i check properties it shows black coloured output and says ATAPI internal jack.
    Strangely there is another entry above that saying Realtek speakers, then a note saying not plugged in. If i check properties it says Realtek Hi Def Audio with all the colour jacks, but there is no way to enable it or make it default. Next to symbol it has red arrow pointing down.
    Any guidance or help would be appreciated
  2. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 06:17 AM
    usa us connecticut
    Re: No sound on any jack
    Welcome
    Probably a driver issue
    Go to search and type the words device manager
    In device manager look for any yellow warning markers or any trees that are in the open position
    If none make sure that your audio drivers are up to date.
  3. #3
    vista home premium
      Thread Starter
    thanks rich but all drivers are working fine i have even deleted and re installed new drivers so its not that i'm afraid.
  4. #4
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    With the realtek problem, were you in an administrtor account?
  5. #5
    vista home premium
      Thread Starter
    yeah i believe so i just cant enable the damn speakers grrrrrrr
  6. #6
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Can you try another jack?
    Have other speakers for a test?
  7. #7
    vista home premium
      Thread Starter
    no sound coming from the headphone jack either and i tried the headphones in the green jack in the back but no use either i have even changed cables i just wish the speakers could re enable the speakers to default i have been online for about 4 hours trying to find a fix
  8. #8
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
  9. #9
    vista home premium
      Thread Starter
    Thanks ill give it a go and re-post results. All your help is greatly appreciated Rich
  10. #10
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Ill try the best I can and then Ill let you know when Im out of ideas. I may be away for a while. Just post and I or someone else will be here to help.
Page 1 of 6 123 ... LastLast
Acer port/Jack no sound problems Foxman Sound & Audio 0 14 Mar 2009
No Sound Through Headphone Jack batman3n1 Vista General 3 31 Dec 2008
Realtek jack detetion issues and no sound bumslie40 Sound & Audio 4 07 Aug 2008
no sound through rear jack sleepyjoe Vista music pictures video 1 07 Jun 2008
Re: No sound - red light in headphone jack Colin Barnhorst Vista hardware & devices 2 05 Jan 2008
