Input monitor volume: no slider
flakhappy
I have vista home premium and I enabled the input monitor via regedit. the strange thing is that the box and mute button for it is there but no slider:
What is going on???
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
What happens when you open up Sound Manager in the Audio Manager now ? Can you check that default speakers and other settings .. etc.. stereo and such are set right ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Re: your posted pic. do you still have muted icon ? click that if you do to unmute it.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
If I delete the registry entry for the input monitor, it is removed completely, but with it enabled all that is there is the mute button which is functional
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
K,, post how it went. someone will get back with you..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
When you ran the file checker. In the Command Prompt window.did it indicate there were files not able to be repaired ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
No.. if it found any Integrity issues. do the scan bout 4 to 5 times to allow it to fix all it can.. Let me know when you have done that. and we can go from there.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Try this next . just to be sure. post me results of this when done. We are not giving up. We will get this for you , one way or another . : No sound in Windows
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
