lisagailsmiles
Hello Forum people! I am having the same audio problem described in this thread:
http://www.vistax64.com/sound-audio/288447-sound-skipping-stuttering.html
I thought upgrading to Win 7 and or a RAM upgrade would fix it, but after some pertinent research, I'm not sure that will solve it at all. I haven't done it.
Before I play a DVD, for example, I disable or 'end process' on almost anything using RAM, and it still happens.
I did a factory-fresh re-install, and it still happens. I don't expect to solve it, now, just want to understand it. Is this a known issue with Vista?
I have a Dell Inspiron 1545 with Vista Home Prem x32, 4 GB RAM, and the audio is IDT HD Codecs.
Whatever other info you need, let me know! Thanks!
- Dell Inspiron 1545
- 4 G RAM
