Anyone know how to take apart a laptop?
  1. #1
    Junior Member
    Vista Home Basic 32-bit
    Local Time: 02:27 PM
    The jack for the headphones has been dislodged somehow and is now lost inside the laptop. I would like to hook up speakers but they won't work in the mic jack. I have it connected to my tv using vga but there's no sound input/output to hook the two together. No HDMI on the laptop either the only thing I can think of is try try opening the laptop and line up the headphone jack or rig it if I have to, to get the speakers to work. Any suggestions? I heard it's probably best off NOT opening a laptop, but it just seems like such an easy fix if the jacks just been pushed in can't I just push it out?
  2. #2
    windude99's Avatar
    Windows Guy
    USA
    Windows 7 Professional X64
    Local Time: 01:27 PM
    Re: Anyone know how to take apart a laptop?
    Quote Originally Posted by rockme77 View Post
    If the headphone jack popped off, you will have to resolder it onto the motherboard. You should take your laptop to a computer repair place to get that fixed.
  3. #3
    Senior Member
    Ultimate x64, home Prem 64
    canada
    You can possibly get a service manual online, but soldering to a board is tricky.
  4. #4
    Junior Member
      Thread Starter
    oh, I just figured it got loose inside and I could push it back out to connect. If that's the case then I won't even bother. Thanks!
Anyone know how to take apart a laptop? problems?
HELP!!!! Laptop died. How do I transfer Windows Mail to my new laptop? rubytuesday Browsers & Mail 9 01 Dec 2011
File Sharing with an XP laptop and Vista laptop on the same networ Daniel Ostro Vista networking & sharing 6 25 May 2009
NEED HELP! Exporting Windows Mail Folders (On Vista Laptop) to Microsift Outlook 2007 (on sep laptop with XP)????? bubymae Vista mail 1 04 Apr 2009
to contact a vista laptop to xp laptop using a crossover cable Brian Boulnois Vista networking & sharing 3 27 Nov 2007
XP Pro laptop cannot find Vista wireless network created on laptop Fluffman Vista networking & sharing 1 25 Jun 2007
