NO Loudspeaker sound in Acer 5720
  1. #1
    Newbie
    Vista Business 32 bit
    Local Time: 01:52 AM
    My Acer TravelMate 5720 has a new "problem." It has good audio via the headphone jack/line out, but no sound from loudspeaker. Further, when the headphones are removed from the jack, the loudspeker icon shows a red "X" and a "mouse-over" says "No Audio Output Device Installed". Similarly on Device Manager no loudspeaker is available. How do I get the Loudspeaker Icon, etc. back to normal and connected in the system. Thanks!
  2. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 02:52 AM
    usa us connecticut
    Re: NO Loudspeaker sound in Acer 5720
    Welcome
    Go to search by the start button.
    Type device manager
    In device manager, update the audio drivers. They may even have a small yellow mark next to them.
    If that does not work, try going back with a system restore to good times.
    System Restore - How to
  3. #3
    Banned
    Windows XP proffessional
    Local Time: 12:52 AM
    Well..you need to install a sound driver for the device, if you do not have it, download for internet using your laptop's model no. and OS name. If it was working earlier and you are not able to find it, try restoring the System, as:
    Run-> Restore-> Enter. Open an icon with green arrow and restore system to an earlier date when it was all fine.
NO Loudspeaker sound in Acer 5720 problems?
No sound from my Acer M5201 dkennion Sound & Audio 15 04 Aug 2009
Acer port/Jack no sound problems Foxman Sound & Audio 0 14 Mar 2009
Problem with my new Acer computer and Sound Forge 8 Papirin Sound & Audio 4 06 Jan 2008
Sound contols on acer asprie 5630 Michael Vista General 2 06 May 2007
Acer Aspire 5050 sound problems turtle king Vista hardware & devices 3 06 Apr 2007
