| | #101 (permalink) |
| Administrator | Re: New Realtek HD Audio Driver Released Hi Skeevee, Have you updated yout BIOS or Chipset drivers to the latest version for your motherboard? If you did, then this may be a hardware failing issue. Try the above. If it does not help, then try a Repair Install to see if it will solve the problem if it is a problem with a file. How to Perform a Repair Installation for Vista Shawn |
| | #102 (permalink) |
| Member | Re: New Realtek HD Audio Driver Released hi, I have purchased a new Dell computer and it came with Vista about 4months ago I love the machine but recently the sound driver was uninstalled. I have no sound now and after spending 2hrs last night on the phone with dell TS they couldnt fix it. HELP I AM CLUELESS!!! Kaire |
| | #103 (permalink) |
| Member | Re: New Realtek HD Audio Driver Released hey everyone my realtek HD config shows i have driver 6.0.1.5404 and it works perfectly should i risk update to 1.81? what ver do i have anyway? 1.54? thanks |
| | #104 (permalink) |
| Administrator | Re: New Realtek HD Audio Driver Released Hi Violent Ken, I have the new 1.81 version and it shows as 6.0.1.5506 in Device Manager. You may have one of the 1.7 ?? versions. So far I have no problems with it. If you do, you can always go into Device Manager and do the Roll Back Driver option. I would go for it. It may help improve it more. Shawn |
| | #105 (permalink) |
| Administrator | Re: New Realtek HD Audio Driver Released hi, I have purchased a new Dell computer and it came with Vista about 4months ago I love the machine but recently the sound driver was uninstalled. I have no sound now and after spending 2hrs last night on the phone with dell TS they couldnt fix it. HELP I AM CLUELESS!!! Kaire Welcome to the forum. ![]() Have you tried reinstalling the audio drivers? They usually have to be install twice. Once to remove the old one, and second to install the new one. Do you know what audio device you have? If not, post your motherboard's model number and we'll see if we can look it up for you. Shawn |
| | #106 (permalink) |
| Member | Re: New Realtek HD Audio Driver Released Brink, Thanks for the welcome. I have tried installing the drivers a few times and everytime it comes up with an error message. I am going to venture to say it is a realtek ALC888 HD Audio device. Like I said before I was online with Dell TS for 2hrs trying everything. Thanks Kaire |
| | #107 (permalink) |
| Administrator | Re: New Realtek HD Audio Driver Released Kaire, Try double checking your audio settings in the Realtek HD Audio Manager in the Control Panel (Classic View). Make sure it is set properly for the type of speaker setup you have. Take a look through this to see what to check. Play with different settings to see if one will do the trick for you. http://www.vistax64.com/sound-audio/85436-new-realtek-hd-audio-driver-released-3.html#post502777 Shawn |
| | #108 (permalink) |
| Member | Re: New Realtek HD Audio Driver Released Brink, I dont have the Realtek HD Audio Manager in the Control Panel..... Kaire |
| | #109 (permalink) |
| Administrator | Re: New Realtek HD Audio Driver Released Kaire, If you do not have the Realtek HD Audio Manager ni the Control Panel in Classic View (Upper left corner), then you do not have the drivers installed from Realtek. http://www.vistax64.com/sound-audio/85436-new-realtek-hd-audio-driver-released.html#post422006 Shawn |
| | #110 (permalink) |
| Member | Re: New Realtek HD Audio Driver Released brink, that is what I have been trying to tell you.. one day my copmuter updated and now I have no drivers installed.. I have spent many hours with TS downloading and trying to reinstall them but nothing has worked there is constantly a timeout error while trying to do so. HOW CAN I FIX THAT? Kaire |
| Realtek HD Audio driver | Vista music pictures video | |||
| back panel not working for latest realtek driver! | Sound & Audio | |||
| Realtek AC'97 audio driver provided by Microsoft. Audio error MCE | Vista hardware & devices | |||
| Latest Creative Beta driver & the latest version of Skype | Vista General | |||
| Does the x64 version of Vista have driver for Realtek 8029AS? | Vista hardware & devices | |||
