Vista Forums Home Join Vista Forums Webcasts Windows 7 Forum Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > System Security
Help from being hacked
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 07-06-2008   #1 (permalink)
Newbie
Vista Home Premium
USA
Ravenna is on a distinguished road
  Ravenna is offline
Hello,
I am being hacked by someone very malicious. At one time there were 3 other PCs on my Norton map view and I have done enough research to find out that someone is using my internet connection with wireless devices.
I myself don't have any wireless devices and have only 1 PC so I know they are not mine. Now they have blocked me out of that page so I can't check if they are there or not. The phone company refuse to help me track them so I am desparately looking for someone who can help me do it myself. I don't have enough knowledge about computers to do it without advice.
I need to know how to find their IP so I can give it to the authorities and get it stopped. I'm so tired of reformatting every week or two because they mess with my system files etc...
If someone is using your internet connection and not helping you pay the bill they are a no good freeloader and I hope someone can tell both of us how to get rid of them!
Old 07-06-2008   #2 (permalink)
Newbie
Vista Home Premium x64
buffalo is on a distinguished road
  buffalo is offline
Re: Help from being hacked
Can you give any more details about your connection/network?
Wireless devices can only access your network if you have a wireless access point broadcasting. Since you don't have any wireless devices yourself, there is no need to have a wireless access point broadcasting on your network - do you? If you are going through a wireless router then you should be able to configure it so that the wireless is turned off. That will stop any hacking on your network.
Old 07-07-2008   #3 (permalink)
damocles's Avatar
virtue & horse hair
Vista Ultimate x64
London
damocles is a name known to alldamocles is a name known to alldamocles is a name known to alldamocles is a name known to alldamocles is a name known to alldamocles is a name known to all
  damocles is offline
....if you do have a wireless access point then you should secure it immediately - it's very easy to do and will eliminate your problem.
Turn off file sharing too.
Old 07-07-2008   #4 (permalink)
johngalt's Avatar
Antidisestablishmentarian
e x86 MAK, XVista Ultimate x64 MAK, Vista UltimatP x64, XP x86, OpenSolaris 5, Gentoo 2008.1....
3rd Rock
johngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant future
  johngalt is offline
Ummm, guess what?
Your router came with an instruction book - if they have 'locked you out' from the settings page, then you can reset the router to factory defaults using the reset button on the back.
Then, if you are not running a wireless connection, ***TURN IT OFF***
Old 07-07-2008   #5 (permalink)
Guru
Vista x64 Ultimate
SCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud of
  SCSIraidGURU is online now
Which OS? Which anti-virus? If Vista, Is UAC enabled? Is firewall enabled? I would start by setting up security on your router. Change its password. Enable MAC filtering and only put in your MAC address. IPConfig/all from a command prompt will tell you it for your connection. Disable wireless, if you are not using it.
Old 07-07-2008   #6 (permalink)
johngalt's Avatar
3rd Rock
  johngalt is offline
why worry about the wireless security when he does not have a wireless device? just disable wireless and be done with it.
Display Modes
Has my Vista been Hacked!? via007 System Security 6 4 Weeks Ago 01:10 AM
Have I Been Hacked? TeeFran Vista security 2 08-30-2008 12:16 PM
Vista Hacked S.Quickness Vista performance & maintenance 11 07-05-2008 08:58 AM
It got hacked... Smithsonian Live Messenger 1 04-11-2008 10:28 PM
Microsoft Got Hacked! corbomite Vista General 6 07-02-2007 06:58 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
