Go Back   Vista Forums > Vista Forums > System Security
Vista - dll problem...i think?
Old 08-20-2008   #1 (permalink)
vista home premium x64
Hi guys, im new to this forum and to vista. i ran into a problem this morning. here it goes
it all started after i downloaded a file and started to install it. first thing that happened was i got an error message saying g.exe couldn't be opened. so i closed it and thought it was funky for it to happen at the time. i also didn;t think it was a file of importance and we all know how windows is. so i figured a restart n i would be ok.
i restarted and i got a rundll error C:/windows/system32/ " the specified module could not be found" ( opnnnoMd.dll ) i did find the file after some searching in the syswow64 folder. and it had been modified around the same time i had the error of g.exe...so i did some searching bout g.exe and found it could be a virus....
i have norton ran an update and scan...found nothing
so i manually searched for g.exe nothing
ive restarted 3 times everytime it starts i get that dll error....what can i do (besides format)
Old 08-20-2008   #2 (permalink)
Vista™ Ultimate x64
Re: dll problem...i think?
Hey mate,
Try to do a Spyware S&D scan.
And you could also try to fix your Vist files by typing "sfc /scannow" in CMD.
Old 08-20-2008   #3 (permalink)
funky thing says i have to be an administrator to run the scan but i am the admin...and im logged into my admin account (only account ive made).... do i need to change something?...ill look around and im downloading scan and destroy now....n get back with a post n a bit
i also ran 2 different register fix programs as i figured maybe when uninstalling something between restarts the reg got screwed...didnt help
is anyone familiar with that dll or the exe im talkin about>
Old 08-20-2008   #4 (permalink)
Vista™ Ultimate x64
You have to run it as administrator.
Start -> Accessories -> Command Prompt -> Right Click -> Run as Administrator
Or just type 'CMD' in start menu search, and then Right Click -> Run as Administrator.
Then you will be able to do a scan.
Old 08-20-2008   #5 (permalink)
i found spy bot search and destroy....it doesn;t say anything bout being compatable with x64...im checkin it out anyways
Old 08-20-2008   #6 (permalink)
found some corrupt files but were unable to fix them....more information in cbs log....but i tried opening and said denied....(didnt see open as admin on it either)
Old 08-20-2008   #7 (permalink)
i downloaded s and d and i tried running it...gave me some funky error as well but program still opened and im running scan
Old 08-20-2008   #8 (permalink)
good news...spybot found a virus...well i guess its good news...man norton sucks a fatty. how is it some program thats got tons of programmers and bull**** behind it and that you pay for doesn;t find a virus that some freeware bull**** can find? i should walk my ass down to symantec and kick there ass and ask for a refund the virus it found was
virtumonde.prx
im gonna restart and see if that fixed my problem
if it did....what virus scanner do u guys suggest? or do i need to be using multiple scanners?...hope no one says norton
Old 08-20-2008   #9 (permalink)
Vista™ Ultimate x64
Check this thread out mate : Here
I personally recommend NOD32, but it's not free.
Old 08-20-2008   #10 (permalink)
well apparently i had a virus but that wasn;t the problem i noticed. im still getting that dll error when i reboot. is there a way to get into the cbs.log to see what was corrupted?
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
