| Vista Ultimate x64, Vista Business x32 | Help Security Account Problem Hi, I moved my computer (Vista Business x32) from a domain (no longer available) to my work group. My domain account had local admin privileges on the machine so I was able to move the machine from the domain to the local work group (domain, admin, domain admin account are all gone). However, I forgot to create a local machine account before I rebooted and now I can't log in at all. Any ideas how I can log in or would I need to reinstall the OS? Thanks in advance for all your help, Feeling like a genius. |
| Vista Ultimate 32 | Re: Help Security Account Problem This is just a guess, but what about disconnecting the network cable, and then logging in to the domain, normally? While the domain does not actually exist, I believe Vista will use its cached credentials. I have seen this work with domains as old as NT, but Vista may have "fixed" this. Good luck. |
| Vista Ultimate x64, Vista Business x32 | Re: Help Security Account Problem This is just a guess, but what about disconnecting the network cable, and then logging in to the domain, normally? While the domain does not actually exist, I believe Vista will use its cached credentials. I have seen this work with domains as old as NT, but Vista may have "fixed" this. Good luck. |
| Vista Ultimate 32 | Re: Help Security Account Problem I see the whole picture now. Sorry for the lame suggestion. I may be about make another lame suggestion, but how about the tapping F8 during boot up, and choosing the menu item for the last known good congifuration? Also, can't you do a system restore from the Safe Mode Console (again, in the F8 start up menu)? |
| Vista 32bit SP1 | Re: Help Security Account Problem You can try to disconnect the network cable at time when you try to login. And then reconnect it when you have logged back in. |
| | #6 (permalink) |
| Vista Ultimate x64, Vista Business x32 | Re: Help Security Account Problem I see the whole picture now. Sorry for the lame suggestion. I may be about make another lame suggestion, but how about the tapping F8 during boot up, and choosing the menu item for the last known good congifuration? Also, can't you do a system restore from the Safe Mode Console (again, in the F8 start up menu)? |
| | #7 (permalink) |
| Vista Ultimate x64, Vista Business x32 | Re: Help Security Account Problem |
| | #8 (permalink) |
| Vista Ultimate 32 | Re: Help Security Account Problem Well, I guess you could mount your drive in another Vista computer and pull the data off. No password should be required for that. Have you tried the Ultimate Boot CD? It is a free boot CD ISO that has all kinds of recovery tools in it. Google the words in bold to find it. |
| | #9 (permalink) |
| Vista Ultimate x64, Vista Business x32 | Re: Help Security Account Problem Well, I guess you could mount your drive in another Vista computer and pull the data off. No password should be required for that. Have you tried the Ultimate Boot CD? It is a free boot CD ISO that has all kinds of recovery tools in it. Google the words in bold to find it. Thanks a lot once again. |
| | #10 (permalink) |
| Vista Ultimate x64, Vista Business x32 | Re: Help Security Account Problem Just checked out the Ultimate Boot CD web site. It uses the same tool for password resets as the one I mentioned in my previous post. Thanks again. |
| Vista Account Password Security | Vista General | |||
| guest account security | Vista General | |||
| How to Map Account Names & Security ID | Vista General | |||
| How to Map account names and security ID | Vista General | |||
| How to map account names and security IDs | Vista General | |||
