| Vista Ultimate x64 SP1 | Firewall problem after updating comodo ! ! After comodo notified me of available updates, i downloaded them, but then at the end the cfp.theme problem occured. I searched the comodo forum and I solved ( I had to run comodo under administrator mode) it but after that, windows no longer recognizes comodo firewall and the security center says that i must enable the windows firewall... Any thoughts? |
| Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro | Re: Firewall problem after updating comodo ! ! Hello nikost. I had the same problem as you; I just un-installed and then re-installed Comodo then all was right again in Bare foot Kid land.... ![]() Later Ted |
| Vista Ultimate x64 SP1 | Re: Firewall problem after updating comodo ! ! Yes I did that in the first place, but the updates are also removed so i have to do that all over again |
| Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro | Re: Firewall problem after updating comodo ! ! Hello again nikost. Are you Installing form the Comodo dl site or from a saved install setup? I have not been offered any updates again. Later Ted |
| Vista Ultimate x64 SP1 | Re: Firewall problem after updating comodo ! ! i have a saved setup from a previous version.. do u have a link from the latest version? |
| | #6 (permalink) |
| Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro | Re: Firewall problem after updating comodo ! ! Hello again. That's the problem the version you have needs to be updated.... ..Have a look here!Free Firewall Protection Software Best Firewall Computer Security Free Personal Firewall Keep us informed! Later Ted |
| | #7 (permalink) |
| Vista Ultimate x64 SP1 | Re: Firewall problem after updating comodo ! ! thanks for the link!!! everything is ok now!! |
| | #8 (permalink) |
| Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro | Re: Firewall problem after updating comodo ! ! Hello nikost. I'm pleased you've found a solution! Later Ted |
| | #9 (permalink) |
| Vista Ultimate x64 SP1 | Re: Firewall problem after updating comodo ! ! sorry to bring back an old thread, but after downloading and installing the latest comodo firewall (3.5.55810.432), the program notifies me again for an existing update which is the same with the version i've just installed.. what's happening? |
| | #10 (permalink) |
| Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro | Re: Firewall problem after updating comodo ! ! Hello again nikost. I'm not sure what that is all about; as I forgot about it about a week ago and let it do the upgrade again with the same result.... ...I had to un-install then re-install all over again. For my money in the future: "if it ain't broke; I ain't gonna fix it". I just haven't been spending much time in Vista lately; as I've been spending most of the time in Windows 7. Maybe someone else has some insight on this problem. Sorry I'm not much help with it right now....![]() Keep us informed! Later Ted |
| question about comodo firewall | System Security | |||
| Comodo firewall now out for x64 | System Security | |||
| COMODO firewall pro | System Security | |||
| Comodo Firewall update addresses Windows Update problem | Vista security | |||
| Comodo Firewall update addresses Windows Update problem | Vista General | |||
