Go Back   Vista Forums > Vista Forums > System Security
Vista - Parental control help...is good_help out there?
Old 11-30-2008   #1 (permalink)
Vista
I read a thread from last year that describes the trouble I'm having but could not locate the crucial answer. The problem is: When I try to set up parental controls using the admin. acct. for my kids' user acct. I get a flash of the screen and then I get the message: "Unable to make changes to parental control settings. If problem persists, see your system administrator." good_help responded with a regedit potential fix that worked for this user but I could not find the answer to the final post below.
The last post from the thread last year read:
"I have found the regedit and have located
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session
Manager\Environment. There seems to be a combination of REG_SZ and
REG_EXPAND_SZ lines in it. I do not know what to do here. I am not sure of
what to do. Do I delete lines or edit them or insert them. Please advise."
I have the same scenario as above but am not sure what to do from here. Thanks
Parental Control Vista account administration
??????????????? Parental Control Vista General
Parental Control for AIM Vista security
Parental Control PIN Vista account administration
