| Windows 7 Home Premium x64 | Help! Trojans, Backdoors etc. One of the computers in our house has contracted a serious illness. We have tried NOD32, Kaspersky, Spyware Doctor, Bitdefender. Spyware Doctor found approx 15 Trojans, several backdoors and other miscellaneous junk. Unfortunately to get rid of them, you must pay 40 dollars! What can I try to get rid of them oh mighty Security Team?? |
| Windows 7 RC x64 Vista HP x86 | Re: Help! Trojans, Backdoors etc. Hello Extensa, First give spybot S&D a Try The home of Spybot-S&D! Then run a full scan with Malwarebytes Malwarebytes.org |
| Windows 7 Home Premium x64 | Re: Help! Trojans, Backdoors etc. I am currently trying Spybot S&D and it is finding several counts of virtumonde trojans. Spyware doctor found over 300 infectious files. I will try malwarebytes next By the way, this computer is running XP Home Edition! |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: Help! Trojans, Backdoors etc. Hi Extensa, Sorry to hear about your problem. Spyware Doctor by PCTools is good at its job, unfortunately, as you have discovered, you have to pay for the product to be fully activated so as to remove any malware it finds. ![]() I recommend Spybot Search & Destroy, available here: The home of Spybot-S&D! |
| Windows 7 Home Premium x64 | Re: Help! Trojans, Backdoors etc. Quick Question: Does Malwarebytes remove the files or do you have to pay to do that like Spyware Doctor? |
| | #6 (permalink) |
| Windows 7 RC x64 Vista HP x86 | Re: Help! Trojans, Backdoors etc. Hello Extensa Due to the finding of virtumonde I would also suggest you have a look at Malwrebytes, rouge Remover also available at their site AFAIK all the relevant Malwarebytes applications are free for personal use |
| | #7 (permalink) |
| Windows 7 Home Premium x64 | Re: Help! Trojans, Backdoors etc. Thanks for your help!! Once Spybot Search and Destroy is done I will use malwarebytes. Funny how going to one bad website can cause such a chaos! |
| | #8 (permalink) |
| Windows 7 RC x64 Vista HP x86 | Re: Help! Trojans, Backdoors etc. Hello Extensa, The fact is that these days you don't have to even click anything on these sites virtumonde is a nasty one but hopefully it will be removable, it may be worthwhile backing up anything irreplaceable, while you can, just in case |
| | #9 (permalink) |
| Windows 7 Home Premium x64 | Re: Help! Trojans, Backdoors etc. The RougeRemover Tool found nothing but within the first minute of starting the antimalware, it found 20 infected files... maybe this one will clear everything out. Once again thanks for the help! |
| | #10 (permalink) |
| Vista Ultimate SP2 x64 Windows 7 Ultimate x64 TECHNET | Re: Help! Trojans, Backdoors etc. You might also try running Vundofix and MSRT as well. MSRT is for XP as well. VundoFix by Atribune Malicious Software Removal Tool |
| Need Help Removing Trojans | System Security | |||
| Impossible to delete Trojans | Vista General | |||
| trojans | Vista security | |||
| Re: Specifically targetted trojans | Vista security | |||
