| XP PRO x64 (see other info) | Antivirus program with low RAM and CPU usage? does avast use very much ram/CPU? i'd like an antivirus program that does not sacrifice performance (or very little) |
| Vista Ultimate x64 SP1 | Re: Antivirus program with low RAM and CPU usage? When Norton put cpu/ram usage meters in their program and brags about it too you know "resources" is not an issue I dont think you find many AV programs which slow down computer in any way you notice. Not resident parts at least. Some are heavier than others - like Kaspersky. You should not care about saving 1-2% cpu usage when you have 100% available. Care more about how stable it runs and how much you can tweak to own liking. Avast lets you play with settings, disable modules you dont use - or see the point in having running. Also exclude folders, drives even. You can decide system is 100% clean and disable scanning for open programs, only new programs/create files. See if you notice a difference, my guess is nope. Avast on-demand scanner seem fairly slow to me but be careful about the logic between speed and quality. Like with defraggers, the fastest can be the worst even if some enjoy the "speed". If for example Avast support 7-zip files (it does) and you have 10000 of those - how bad would it not look compared to other AV which skip all 7z files? Much easier if you just tried it out. If you like it you can definitely also live with resource usage. If you dont like it will be uninstalled even if light as a feather. I think they are working on a new 5 version, assuming they dont screw up it is not likely to become slower than 4.x. |
| Vista Ultimate X64 SP2 | Re: Antivirus program with low RAM and CPU usage? NOD32 has the fastest/most acurate scanning, with the smallest resource footprint. Free ESET Online Antivirus Scanner For futher info on antivirus products (how well they perform) Vista SP1 Antivirus Performance |
| Vista Ultimate x64 SP1 | Re: Antivirus program with low RAM and CPU usage? Well he was asking about Avasts cpu/ram usage. May be find AV-comparatives Performance report from october 08 which is somewhat relevant - and showing another picture, 9 AV products all got highest ranking, including Avast and ESET Also note until that report they would not do such a test and still regard it as an introduction and mainly focusing on real time scanner. Some did not get Advanced+ because of 1 test they say is "highly controversial". They are good at testing because they make an effort and dont hide conditions, like so many others who dont write long pdf files, but this one is close to not so important. |
| Vista Ultimate X64 SP2 | Re: Antivirus program with low RAM and CPU usage? Well he was asking about Avasts cpu/ram usage. May be find AV-comparatives Performance report from october 08 which is somewhat relevant - and showing another picture, 9 AV products all got highest ranking, including Avast and ESET Also note until that report they would not do such a test and still regard it as an introduction and mainly focusing on real time scanner. Some did not get Advanced+ because of 1 test they say is "highly controversial". They are good at testing because they make an effort and dont hide conditions, like so many others who dont write long pdf files, but this one is close to not so important. Last edited by rive0108; 01-19-2009 at 10:52 AM.. |
| | #6 (permalink) |
| Vista Ultimate x64 SP1 | Re: Antivirus program with low RAM and CPU usage? May be you should make a thread about your favorite AV then? Dont see what your posts has to with question asked. |
| | #7 (permalink) |
| Vista Ultimate X64 SP2 | Re: Antivirus program with low RAM and CPU usage? An antivirus product that has a small footprint, but inferior protection is a useless program IMO as it results in low resource usage UNTIL you are infected by malware and viruses which then can put an excessive load on the system that can cause corruption and loss of system functionality (thus defeating the purpose of a small footprint AV program in the first place). One has to look at the bigger picture here: Do you want a AV program that performs and protects, or one that doesnt? Last edited by rive0108; 01-19-2009 at 11:01 AM.. |
| | #8 (permalink) |
| Vista Ultimate x64 SP1 | Re: Antivirus program with low RAM and CPU usage? No it is not, he mentions Avast in particular and not what is "best" - as if that would be interesting. There is much reason to think he also would prefer free AV btw. I think you should read their pdf-files instead of just refering to stars and gold medals. How come higher detection rate than ESET give lower ranking for example? Does it matter, why and why not? How come Avast can go from + to no + - and will that change in 2-3 months? It is a bit more complicated than one-liniers. AV-Comparatives do their stuff to prevent that way of looking at this. When they pick and rank they evaluate more than a few parameters. If you look at their questionable performance report you will see only 2 regular AV programs can be said to fall out of the frame. Avira was chosen as AV of the year by AV-Comparatives so may be time to change current favorite? |
| | #9 (permalink) |
| Vista Ultimate X64 SP2 | Re: Antivirus program with low RAM and CPU usage? No it is not, he mentions Avast in particular and not what is "best" - as if that would be interesting. There is much reason to think he also would prefer free AV btw. I think you should read their pdf-files instead of just refering to stars and gold medals. How come higher detection rate than ESET give lower ranking for example? Does it matter, why and why not? How come Avast can go from + to no + - and will that change in 2-3 months? It is a bit more complicated than one-liniers. AV-Comparatives do their stuff to prevent that way of looking at this. When they pick and rank they evaluate more than a few parameters. If you look at their questionable performance report you will see only 2 regular AV programs can be said to fall out of the frame. Avira was chosen as AV of the year by AV-Comparatives so may be time to change current favorite? my fault I thought the thread starter was asking about small footprints AND performance ![]() BTW, It s not just AV-Comparatives, but also Virus Bulletin. I evaluate according to "Certified" Lab test results of real world malware detection rates, and find no value in "editor's Picks" (as most Editor's picks are a result of a Vendor paying them to promote their AV).Avira is ok (other than the fact that it detects legitimate programs as malware excessively which results in system/program instability and corruption) |
| | #10 (permalink) |
| Windows Vista X64 | Re: Antivirus program with low RAM and CPU usage? Rite now believe it or not Norton AV 2009 ( Either the normal one or gaming edition one, both rock) |
| about the change of antivirus program | Vista security | |||
| Suggestions for Antivirus program for Vista | Vista General | |||
| The Best antivirus/Antimalware Program currently Available | System Security | |||
| Antivirus Program Flawed? | System Security | |||
| Do I Really Need an Antivirus Program? | Vista General | |||
