| VISTA Home Premium 64 bit | What AV to use with Vista Home Premium 64 bit About 4 weeks ago I took the leap into Vista despite all my colleagues warnings and installed on a new VAIO laptop! I installed very little in the way of software, just Microsoft Office 2003 and Norton 2009 AV. The sytem kept freezing and I had to do several restores. I noticed when if froze the window "Norton is performing background tasks" often showed up. After two weeks, after I did the latest Microsoft recommended update, this happened again, but this time I could not restore. So now I have done a complete system recovery, but have not tried to connect to the internet because I don't know what AV to use. I keep getting conflicting stories about Norton vs Kaspersky. Meanwhile,isn't Microsoft phasing out LiveOne Care in June? What do you suggest I do so I can get back on the Internet? |
| Vista Ultimate x64 SP1 | Re: What AV to use with Vista Home Premium 64 bit Try AVG Free Edition, it's highly rated by PC World, Cnet and ZDNet and best of all Free! |
| Vista Home Premium SP2 32bit / Windows 7 Home Premium 32 bit | Re: What AV to use with Vista Home Premium 64 bit I use NOD32 on my Home Premium but it's a paid for program Avast is highly thought of and there is a free version that works fine on Vista. Trouble is you will get lots of recommendations about what AV to use but it really all comes down to what suits you and your machine the best. Most have a trial version you can try to see if it suits you or you could try the free ones to see which you prefer, it really all comes down to personal choice in the end. |
| Vista Ultimate X64 SP2 | Re: What AV to use with Vista Home Premium 64 bit ! I installed very little in the way of software, just Microsoft Office 2003 and Norton 2009 AV. The sytem kept freezing and I had to do several restores. I noticed when if froze the window "Norton is performing background tasks" often showed up., but have not tried to connect to the internet because I don't know what AV to use. I keep getting conflicting stories about Norton vs Kaspersky. Meanwhile,isn't Microsoft phasing out LiveOne Care in June? note- Vista recommends 2GB of RAM- anything less will cause freezing and "slide-show" like effects. AVG is ok, but has had some issues recently with viruses gettting through, and updates that would crash a pc-resulting in the need for Vista re-installation. "PC World"/"Cnet"/"ZDNet" are not Certified Labs known for Antivirus testing, nor do they do testing of the products they recommend-their endorsement is what is known as "Editor's Choice", and most of these result from Antivirus vendors who pay them to promote their Antivirus product. You should take an "editor's Choice" with a grain of salt, and instead look at the comparatives done by Certified Labs (i.e., AV-Comparatives, and Virus Bulletin are two of the most well known Comparative Antivirus testers) I use NOD32 on my Home Premium but it's a paid for program Avast is highly thought of and there is a free version that works fine on Vista. Trouble is you will get lots of recommendations about what AV to use but it really all comes down to what suits you and your machine the best. Most have a trial version you can try to see if it suits you or you could try the free ones to see which you prefer, it really all comes down to personal choice in the end. ![]() New NOD32 4 & Smart Security 4 Released!!! To see how different Antivirus programs performed in Vista lab/comparative testing- Certifications acheived, and products that failed, see this sticky: Vista SP1 Antivirus Performance Last edited by rive0108; 03-08-2009 at 03:41 PM.. |
| ip4200: Vista Home Basic Fails, but Home premium works | Vista print fax & scan | |||
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | Network & Sharing | |||
| Updating from Home Premium to Ultimate and moving Home Premium | Vista installation & setup | |||
| Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H | Vista General | |||
| Windows XP Home (Full Vers.) to Vista Home Premium Upgrade (Academ | Vista General | |||
