| Vista Home Premium 32bit | Problem with VB-Script Warning Hello @ all my english is not the best but i do my best that you undersand my problem :-) I have a Program what asking a internet database for an entry. Everytime the program aks there coms a security warning wich asking me if i allow this program to use vb-script. If I`m not at the comuter the warning closes all the running programs... So how can i disable this scurity warning? thanks 4 help |
| Script problem with Windows 7 | VB Script | |||
| problem passing args to script 'There is no script engine for file extenstion' | VB Script | |||
| Problem with convert from WSH-script | PowerShell | |||
| script warning | PowerShell | |||
| Critical,Warning and Error startup and shutdawn problem. | Vista performance & maintenance | |||
