Go Back   Vista Forums > Vista Forums > System Security
Vista - Problem with my security center.
Old 06-19-2009   #1 (permalink)
Vista Home Premium 64bit
My internet was acting up unlike it usually does, and in an attempt to get it back to normal, I shut down and restarted my laptop. When I shut it down, vista installed an update. When I turned it back on, not only was the internet (wireless or otherwise) unavailable, but the Security Center was not running, and my audio service was offline. I found a method that was supposed to fix the security center problem. I set the startup type back from disabled to automatic, but when I click 'start' I get "Windows could not start the Security Center service on Local Computer. Error 1068: The dependency service or group failed to start." I get the same error message with my network connections. I'm using my desktop right now.
Any help?
Edit: Just tried to run System Restore, and I was unable to. Also tried to back up my hard drive, this won't run either. What is going on???
Old 06-19-2009   #2 (permalink)
Vista Ultimate 32bit SP2
Re: Problem with my security center.
Hi haplo4,
I have no clue, but would recommend you to run some malware scans as a start anyway. It is always step one when troubleshooting odd issues.
Try the MRT first. Then try one or two of Malwarebytes, Spybot and SuperAntispyware. Do not install anything that run memory resident like TeaTime. Then try some OnLine-scanners.
When you feel confident you are malware free, and this may very well be the case, report back to the forum, and I think someone will be able to help you fix your problem.
Old 06-19-2009   #3 (permalink)
Well, umm thanks! but I actually figured it all out on my own. It was just a lot of services that had somehow been disabled. I just need to find some codecs for the audio device.
Old 06-19-2009   #4 (permalink)
Quote  Quote: Originally Posted by Haplo4 View Post
Good to hear you sorted it out.
Norton Internet Security 2008 and Vista's Security Center Vista security
Vista Security Center Aero Problem? Vista security
Problem with Windows Security Center not seeing my Antivirus Program Vista installation & setup
Re: Please Help me with security center problem Vista security
RE: Please Help me with security center problem Vista security
