| Vista Ultimate x64 | Setting UAC Control to allow certain Programs Basically I do not want to completely turn off the UAC because i like what it does. I think it is a great addition to vista and win 7. I have eVGA Precision (GPU overclocking and monitoring software) set not to run at startup. but to start and up the default videocard fan speed. then it closes, its a setting in the program. So i have it set to turn up the fan speed at startup. but the program doesn't continue to run. BUTTTT everytime i start the PC the annoying UAC pops up instantly wanting me to "allow" evga precision to run. So can I setit to ALWAYS allow it.. without disabling the UAC Thanks!!! Help will be rewarded |
| Vista Ultimate x64 Service Pack 2 | Re: Setting UAC Control to allow certain Programs You can set the task scheduler to start your program at a given time or on a given date, or after certain other criteria have been met, since the task scheduler is elevated the UAC will not activate, if you want to start it from a shortcut, you can set it up in task scheduler, then create a shortcut to the the task like so c:\Windows\system32\schtasks.exe /run /tn "[folder]\[taskname]" more information on how to do this is available here Bypass UAC using a Desktop Shortcut Basically I do not want to completely turn off the UAC because i like what it does. I think it is a great addition to vista and win 7. I have eVGA Precision (GPU overclocking and monitoring software) set not to run at startup. but to start and up the default videocard fan speed. then it closes, its a setting in the program. So i have it set to turn up the fan speed at startup. but the program doesn't continue to run. BUTTTT everytime i start the PC the annoying UAC pops up instantly wanting me to "allow" evga precision to run. So can I setit to ALWAYS allow it.. without disabling the UAC Thanks!!! Help will be rewarded Last edited by ghost; 07-27-2009 at 01:23 PM.. |
| Vista 32 Home Basic Service Pack 2 | Re: Setting UAC Control to allow certain Programs You can try this. |
| Windows Vista™ Ultimate x64 | Re: Setting UAC Control to allow certain Programs You can try this. |
| Vista Ultimate 64-bit, SP2 | Re: Setting UAC Control to allow certain Programs Personal opinion only - Anything Norton I tend to avoid - like the plague. |
| | #6 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Setting UAC Control to allow certain Programs You can try this. |
| | #7 (permalink) |
| VISTA HOME PREMIUM X64/ 7 x64 / 7x86 | Re: Setting UAC Control to allow certain Programs Works great for me too. |
| CPU/System Fan Control setting in bios | Vista hardware & devices | |||
| setting association control panel | Vista mail | |||
| setting the association in control panel | Vista General | |||
| Setting default programs | Vista General | |||
