| uhm | trojan virus removal help? ESET Smart Security says that it has put a PDF/Exploit. Gen Trojan into quarantine. I read somewhere that if it is put in quarantine that it will not necessarily infect your computer. Is this true? And how would I get rid of trojan? I know nothing about this, basically. |
| Vista Ultimate 64-bit, SP2 | Re: trojan virus removal help? Hello stephenie, Leave PDF/Exploit. Gen Trojan in quarantine where it should present no harm to your computer.[ I suggest that you don't delete it at this stage.] I further suggest that you join this forum [ link below ] which is the "Official ESET Support Forum" at Wilders Security Forums. Address your question to the relevant section [ ESET Smart Security Forum ] & I'm sure that you should receive good advice. Please post back here later & let us know how you went. Good luck. Official ESET Support Forum - Wilders Security Forums |
| Windows 7 Ultimate x64 | It doesn't need to be quarantined. Delete it asap. |
Trojan removal | System Security | |||
| Lmok d Trojan removal? | System Security | |||
| OT Virus/Trojan | Vista General | |||
| trojan removal? | Vista security | |||
| removal of win32:trojan-gen. virus | Vista security | |||
