Go Back   Vista Forums > Vista Forums > System Security
Vista - combofix / NIS2009 problem
Old 09-01-2009   #1 (permalink)
vista home premium 32 bit
im having a problem with my NIS2009 coz it results to 0 scanned files. i use sysprot anti root kit. then a friend help me and ask me to run a combofix. but my bad i forgot to attach the files that he gave me. First run i never used the script so he said Combofix did not get all of the rootkit, it didn't have the correct switch either,
Second time around i did use the script, (that i didn't use first time) with the switches, so he said It pulled the rest of the actual rootkit.
is it bad?
what should i do now?
Old 09-01-2009   #2 (permalink)
Vista Ultimate 64-bit, SP2
Re: combofix / NIS2009 problem
ekai,
It is often a very bad idea to take a friend's advice before checking out very carefully what they are recommending.
Which site did you download ComboFix from?
Were you aware that -
[Quote] You should not run ComboFix unless you are specifically asked to by a [technical] helper. Also, due to the power of this tool it is strongly advised that you do not attempt to act upon any of the information displayed by ComboFix without supervision from someone who has been properly trained. If you do so, it may lead to problems with the normal functionality of your computer.[Quote]
Please provide far more details about your computer & the problems that you have noticed or are experiencing.
Old 09-01-2009   #3 (permalink)
JMH
Thanks for your advice. What do you think I should do? I got my combofix from Bleeping Computer - Computer Help and Discussion
My laptop now is ok but im afraid that something might happen.
Ekai
Old 09-01-2009   #4 (permalink)
ekai,
Good to know that ComboFix was downloaded from one of the recommended places.
Please list what firewall you are using.
Are you using Defender?
Is your Vista fully updated?
What browser are you using? [IE7 or 8]
Is UAC enabled?
Do you scan with NIS regularly?
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
