Can a Virus Spread Over Wireless LAN?
  1.    07 Jun 2011 #1
    Vista x32
    Local Time: 14:43
    Hi, ive been wondering for a while, say if a laptop had a virus on it, and it was connected to the internet using my wirerless router, can that virus spread to the main computer? Or the other way around if the main computer had a virus, when the laptop connects to it, can a virus spread over to it using the wireless internet?
  2.    07 Jun 2011 #2
    Northamptonshire, England
    Windows 7 Professional x64; Windows Server 2012 R2 Standard
    Local Time: 20:43
    uk uk england
    Re: Can a Virus Spread Over Wireless LAN?
    There is a difference between a lot of malware and you should take note
    A virus itself cannot but a Worm can
    Worms can run outside of your bandwidth and slowly destroy your Router it can also move onto other computers
    Hope This Helps,
  3.    07 Jun 2011 #3
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 15:43
    usa us connecticut
    If you are concerned make a full anti virus scan. Then download and run a full scan with malwarebytes. Update both first. In the future run a scan with both once a week.
  4.    21 Jun 2011 #4
    Local Time: 14:43
    Yes it can, but not very likely. Most viruses only infect the computer that got it, but if its a really advanced virus, it can spread over your home network and infect other computers connected to that network.
    Zonealarm coupon
Word Paste from internet spread out
When I paste something from the internet into a word document, its always spread out vertically down the page with huge gaps between sentences and...
Preventing virus spread
The thought was to do all my work in the guest and nothing in the host. Both will be XP, fully patched, with firewall and antivirus protection. ...
Virtual PC
Find the last Row in an Excel Spread Sheet
Here we go again. When I get done I will publish an Excel Cookbook for PowerShell. In the mean time; In vbScript; Const xlCellTypeLastCell...
Spread Spectrum
I recently built a new PC. Asrock p45 mb, e8500, WD 250 sata2 hd, ddr3 1333. Does anyone know if spread spectrum should be enabled in bios? In the...
General Discussion
How do I show all files at once when they r spread between many fo
I have about 3,500 files, spread between about 1,500 folders, and I want to view all files at once in one big list. I was wondering is it possible...
Vista file management
print out spread sheets
I would like to know if i can print out blank spreadsheet that has the col. letters and the row no.
Vista General
spread sheet
why cant i merge cells on my spreadsheet ?
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
