Originally Posted by
Brink
Hello Digihax, and welcome to Vista Forums.
It sounds like DEP may be disabled. Check using the tutorial below to see if enabling DEP may help.
DEP - Enable or Disable
Hello Shawn I have read that after I posted and did;
1. Open a
elevated command prompt.
2. To Enable DEP A) In the elevated command prompt, type in bold below and press
Enter. (See screenshot below)
NOTE: If for some reason this command does not enable DEP after restarting the computer, then use the bcdedit.exe /set {current} nx AlwaysOn command instead.
bcdedit.exe /set {current} nx OptIn
B) You should get a success message back
C) Close the elevated command prompt.
D)
Restart the computer to apply.
But sadly to no avail, I did download but not installed the program and got the pdf of EMET though
