Vista Tutorial - Shutdown Options - Start Menu
Comment
Old 11-08-2007
Brink
Administrator
How to Remove or Show the Start Menu Shutdown Options in Vista
Old 06-23-2008
Brink
Administrator
Re: Shutdown Options - Start Menu
Ok,
I would do a System Restore using a restore point dated befor this problem to see if it can fix it then. If not, then you can do a Repair (upgrade) install. This tutorial will show you how to if needed.
Repair Install For Vista
Old 07-24-2008
xslydarkx
Newbie
Vista Home Premium 32bit.
ok i did the noclose option and i did the powercfg -h on they oth did not work and for some reason now i cant use "run" if there is any way u can help i wud owe u one for the rest of my life Thxz
Old 07-24-2008
Brink
Administrator
Hi xslydarkx, and welcome to Vista Forums.
Ok, first things first. Can you post back more details on what exactly your problem is? It can help determine what to do for a solution. I am assuming that you are missing your shutdown options. Any error messages?
Old 08-28-2008
DaveA
Newbie
I would like to REMOVE only the Sleep, as I have already gotten rid of Hibernation.
I want to still be able to "Reboot and Shut down".
What do I need to do the remove only Sleep?
Old 08-28-2008
Brink
Administrator
Hi Dave, and welcome to Vista Forums.
I believe this may do what you are wanting.
Removing the Sleep function in the Shutdown menu
Old 09-02-2008
pixelroom
Newbie
Vista Home Premium 32Bit
This doesnt work for me at all, tried to restore it to an earlier point and it also didnt fix my problem.
I have the exact same problem as in this thread, Restart, shutdown, etc. missing from start menu
Would love an problemsolver to help me with this!
Old 09-02-2008
Brink
Administrator
Hi Pixelroom, and welcome to Vista Forums.
If you are confortable in the registry, then open regedit and click on Edit (menu bar) and click on Find. Type in NoClose and click on Find Next. Right click on any NoClose entry it finds and click Delete, then Yes to confirm. Click on Edit and Find Next, then repeat the above until it says it is finished.
Old 09-02-2008
pixelroom
Newbie
So I tried it, and it didnt find any NoClose at all =(
Old 09-02-2008
Brink
Administrator
Ok, Pixelroom.
Have you used any 3rd party utility programs that had this as an option to remove?
The only other thing I know to do to fix this is a Repair (upgrade) install.
Old 09-02-2008
pixelroom
Newbie
someone did install vista os x that i uninstalled
Comment
Tutorial Tools
Tutorial Category
Modify Shutdown Options Menu ?? General Discussion
Restart, shutdown, etc. missing from start menu General Discussion
Vista Start Menu Options Vista performance & maintenance
Shutdown/Lock Button on start menu Vista General
Vista Start Menu Options Vista file management
