Personal User Shell Folders - Move Location
How to Change a Personal User Folder Location in Vista
The personal user folders can be redirected to, and all files inside them, another partition, hard drive, or folder location to be stored in instead. The folder will still be in the (user name) location in the Start Menu as usual, but it will act like a shortcut to the new location instead.
This can be handy if you would like to save space on the drive or partition with Vista on it, or you prefer to just store the files in the use folders at another location.
If a personal user folder has been deleted, is missing, or does not work propely, then see: How to Restore a Missing Personal User Folder in Vista
  • If you have a program that places a folder in one these user folders, like the Documents folder, then you do not want to change it's location until you change the setting in the program to use another folder or the new personal folder location. Deleting the program's folder usually does not do any good. It will just be added back by the program. If you do not, then you will have two undeletable copies of the user folder. Example: Windows Live Messenger puts and uses a folder in the Documents folder.
  • If you change the Favorites folder location, it will no longer show work from within IE7 unless you change the permission level of the new Favorites folder to give Authenticated User full control. For how, see: How to Change Folder Permissions
  • If you use Windows Mail or any other email program that uses the Vista C:\Users\(user name)\Contacts folder for contacts, then do not change the Contacts folder default location to keep using Contacts in these programs.
EXAMPLE: Personal User Profile Folder Icons
NOTE:
Location is at C:\Users\(User Name)
METHOD ONE
Through the User Folder Properties
1. Right click on a personal user folder and click Properties.​
NOTE: Open the Start menu and click on the username button to see them.
2. Click on the Location tab. (See screenshot below)​
3. To Find the Personal User Folder Location
A) Click the Find Target button. (See screenshot above)​
NOTE: This will open a window with the personal user folder location. You will see the full path of the location above the three buttons.
4. To Change the Personal User Folder Location
A) Click the Move button. (See screenshot above)​
B) Navigate to the location you want to use to redirect the personal user folder to. (See screenshot below)​
C) Right click on a empty area in the Select a Destination window and click New and Folder.​
D) Rename the New Folder to the same name as the personal user folder and leave it highlighted, then click on the Select Folder button.​
WARNING: Do not select another personal user folder to redirect this personal user folder to. You will not be able to use the Restore Default location option. Only use a New Folder.​
E) Click OK. (See screenshot below step 2)​
NOTE: You should see the new full path location above the three buttons.
F) Click Yes. (See screenshot below)​
NOTE: This will move all the files inside the personal user folder to the new location.
WARNING: If you do not click Yes, then you will have two copies of the personal user folder in the (your username) folder.​
5. To Restore the Default Personal User Folder Location
A) For how, see OPTION TWO here: How to Restore a Missing Personal User Folder in Vista
METHOD TWO
Through the Registry Editor
This method will show you how to change only the Downloads (long number), Desktop, Documents (Personal), Favorites, Music (My Music), Pictures (My Pictures), or Video (My Videos) user folder default locations.
1. Go to the location in Windows Explorer for where you want to move the user folder location to.​
NOTE: For example, in C:\Program Files.​
WARNING: Do not select another personal user folder to redirect this personal user folder to. You will not be able to use the Restore Default location option.​
A) Right click on a empty area in the window and click on New and Folder. (See screenshot below)​
B) Leave the folder named New Folder.​
NOTE: This new folder example location of C:\Program Files\New Folder will be used and replaced by the user folder.​
C) Leave this window open.​
2. Open the Start menu.​
3. In the white line (Start Search) area, type regedit and press Enter.​
4. In regedit, go to: (See screenshot below 5)​
NOTE: You can see the default paths for the user folders under the Data column.​
Code:
[/INDENT]
[INDENT]HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders[/INDENT]
[INDENT]
5. In the right pane, right click on the personal user folder you want to change the location for and click on Modify.​
6. To Change the Personal User Folder Location
A) Type in the full path of the new location with the New Folder, and click on OK. (See screenshot below)​
NOTE: For example, C:\Program Files\New Folder.​
B) The registry will now look like this. (See screenshot below)​
C) Close regedit.​
D) Go back to the new location in step 1 above.​
E) Right click on New Folder and click Rename. (See screenshot below step 1C)​
F) Type in the name (EX: Music) of the user folder you want to change the location of, and press Enter.​
NOTE: The folder will now change to the special green color with the name of the user folder.
G) Open the Start menu, and click on your username folder button.​
NOTE: You will see two of these user folders (EX: Music) with the same name now.​
H) Right click on each one separately and click Properties.​
I) Delete the one that does not have the Locations tab in the Properties window. (See screenshots below)​
7. To Restore the Default Personal User Folder Location -
Updated 2-12-2008 to include METHOD TWO for the registry.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
I have somehow managed to corrupt my pictures personal folder link. By this I mean when I press START, then try and press PICTURES in the right hand personal folders panel nothing happens.
Right clicking on PICTURES and properties yields a single empty dialogue box, no tags to choose from or anything to edit.
How can I delete or recover this option?
    Intel 2.4 GHz Duo core
    Asus P5W DH Deluxe
    4GB Corsair
    EN8600 GTS
    Creative SB extreme
    HP w2408h
    1920 x 1200
    WD SATA 74GB Rapier + 500GB
    Exp. Index=5.6
    MSFT wired
    MSFT Optical
Hi londonblue,
Delete the Pictures folders, then do OPTION TWO at the top for a missing folder.
Make sure that Pictures has the default location in the registry when you get to that step.
Slendid! Thanks Shawn, all back to normal again. I've wanting to sort that out for months.
Couple of points I noticed in the instructions (which were otherwise great) in method 2, 6B references a screen shot that shows drive D, I think it should be C\program files etc and for step 1 you suggest using as an example c\program files\ for the new folder, well I tried using the root directory at first. This doesn't work. I'd just say use the program files folder.
Anyway thanks again.
Jason
    Asus P5W DH Deluxe
    4GB Corsair
    EN8600 GTS
    Creative SB extreme
    HP w2408h
    1920 x 1200
    Exp. Index=5.6
    MSFT wired
    MSFT Optical
Hi Jason,
Thank you for pointing out that screenshot. It has been corrected. I'm glad to hear that it helped you sort out your problem.
Hi Brink -
Can you clarify warning you gave up front "WARNING: If you have a program that places a folder in one these user folders..."
Do you mean some applications refer directly to the fully specified path rather than use the userprofile location? Is there any way to tell beforehand whether an app is userprofile savvy - I see that Skype, Nero, SyncToy 1.4, RegRun, Visual Studio, Canon Utilities and possibly Nokia PC Suite (which I isn't savvy about anything!) have all created folders in Documents...
... and were you saying that if an app isn't "fixed" before the move, the creation of a folder using an explicit path will create another "Documents" folder under my username...
I want to do this but I'm a bit hesitant given that it seems I might have a rather upset system afterwards due to apps I can't control/don't know about yet!
Julian aka Julian-I-Do-Stuff <g>
Hi Julian,
Welcome to Vista x64 Forums. :party:
You nailed it. It depends on the program. Some use the %UserProfile% path where others use the specific C:\Users path. Sometimes there may be an option in the program that will allow you to specify a default path instead of the default Documents folder.
I suppose you truly would not know until after you moved the user folder location. If it does create a second user folder to accommodate the program afterwards, then you can just restore the default location for the original folder that you relocated and delete the second user folder if it does not merge back on it's own. This way you will be back to where you started. You could also create a System Restore before you do this to use just in case.
Thanks for the confirmation of part of my conjecture - but having said that one would end up with two undeletable folders in the warning, how does that fit with the above?
If say AppX creates in C:\User a folder called AppXStuff, and I move Documents - including AppXStuff - then when AppX next runs it will say, ""here's my damn folder?" and create a new one at C:\User... if I then "restore" the default location of Documents you're saying that Documents\AppXStuff will be merged into C:User\...? Or is it somewhat "less deterministic" than that whether it gets merged back... or the Restore works?
As for System Restore... chance would be a fine thing!
[I hope to have some info on which you might base a new tutorial to shrink System Restore points & hence increase history etc. for Vista Basic/HP users... as it stands I have restore points for today and yesterday... Wow!]
Cheers,
Julian
Julian,
It is "less deterministic". If the program use the specific C:\Users location, then it will create a new folder to have it's folder in. You can then just delete it and restore the default location for the user folder to have things back before you moved the location. The program will add it's folder back to the restored default location. In the worst case, all you will have to do is delete both user folders, then treat it has a missing user folder and do Option Two to restore the user folder to default. The System Restore is just extra insurance.
Thanks Shawn...
Sorry to be a bit stupid about this but I think I'm still missing something...
If I move Documents, and an app creates its own folder using a C:\Users path then there will be e.g. C:\Users\UserJ\Documents\AppFolder.
Assuming the App or OS takes proper care of things "UserJ" should in fact be the same "Julian.myPC" as there is in my current Documents path - and there is then a new folder hierarchy where the user shell folders used to be, identical in structure but not actually the user shell folders...
And since the User Shell Folders are actually somewhere else now, why should there be any problem at all? Good apps continue to work through the %userprofile% path, bad apps use their own into C:\Users and I don't quite see how this leads to any conflict?
Don't suppose for Apps that insist on using c:\users there is anyway to create a folder shortcut or some other "junction" (to replace the actual folder) that then steers it back into the "correct" %userprofile% location... is there?
Or am I just being my usual over-complicated-completely-missing-the-point self?
Julian
Julian,
No, your not being over complicated at all. This whole business with junction points is a bit tricky as is. When you throw in changing the location and programs that use the old location by default, it gets even more trickier.
When you move the C:\Users\UserJ\Documents folder's defaul location, there will still be a Documents folder in the Start menu. It will just now be a shortcut (junction point) to the new location where it actually is now.
Any application that places it's own folder in the Documents folder, will continue to work no matter what. If it uses the %userprofile%\Documents path, then it should follow your Documents folder to it's new location without any problems. If it uses the C:\Users\UserJ\Documents path, then it may or may not follow the Documents new location. If not, it will simply just create a C:\Users\UserJ\Documents\appfolder to use. The only problem is that you will have two Documents folder in the Start menu that could potentially trick other programs in not seeing the new Documents folder location now because of the one created by the application.
The only way to stop a app from doing this is by uninstalling it, or if the app has a setting that you change manually to point the app to use the new Documents location instead. For example, Windows Live Messenger has a setting where you can have it place it's folder anywhere you like instead of just the default Documents folder location.
OK, I searched the forum and cannot find an answer to this:
I've installed Vista Business x64 3 times and this problem has always occured. In all three installations I've relocated the desktop user folder to a hard drive root. In so doing, Windows seems to be unable to remember my desktop icon settings (always float left and become "medium") and my start menu doesn't show my "Show on Start Menu" icons (where IE and Mail are by default). As soon as I move the desktop folder back to it's default location this issue stops.
During the first two installs I thought it was because my original XP installation had the permissions for the drives (both the root I want for my desktop and the partition I made for Vista). However, on my most recent install, I flattened all the drives and repartitioned them using Vista itself, yet the problem still occurs.
I searched the registy for any keys matching "\desktop" to see if anything was still dependant on the original location, but nothing turned up. There's nothing else I can think of that would be causing this problem except a possible super-hidden file that isn't on my drive root.
Anyone have any ideas?
    HP DV8000
    AMD Turion 64 Mobile (2.20GHz)
    HP 430180-001
    2GB SDRAM w/ 4GB ReadyBoost, 256MB Video RAM
    ATI Radeon Xpress 200M
    internal
    internal
    1680 x 1050
    3 120GB (2 internal, 1 ex.) and a 1TB external (all Western Digital)
    internal
    Black like a stallion with silver trim.
    I tilt my laptop up from the back...
    internal 104-key Windows QWERTY
    Microsoft Wireless Notebook Optical Mouse 4000
    um...fast?
    My computer is pretty.
Hi DKqwerty,
Welcome to Vista X64 Forums. :party:
I tested this by doing what you did and it works fine for me with the Desktop folder. The only thing is since the Desktop is being actively used by Vista, it will leave a second yellow Desktop folder in the Start menu for reference. Other than that the Desktop is effectively relocated to C:\.
Did you create a new folder in the C:\ location to use?
Hi DKqwerty,
Thanks for the response and the welcome.
No, I did not create a new folder in the drive root. And it's not C:\ that I'm making my desktop, it's E:\. I fail to see the need of the "New Folder" in your tutorial, it's a very redundant step. I simply used location tab to move my user desktop folder to "E:\". Everything about it works as it should (or should I say, as it did in Tweak UI for XP), including the alteration of the registry key as per your method 2. In the User folder, what was once the desktop folder disappears and is replaced with with a drive icon like in My Computer (histogram and all). I just fail to see why it can't save my desktop icon and start menu preferences only when I move the desktop, which isn't the location of those settings anyway. It's not a crippling scenario, so I don't mind it. It's just a pain in the ass, ya' know?
(Also, I didn't fully understand your comment about the start menu duplicating a desktop folder...there is no "desktop" folder in my start menu.)
    HP DV8000
    HP 430180-001
    internal
    internal
    1680 x 1050
    internal
    um...fast?
DKqwerty,
I was referring to the User folder button on the right dark side of the Start menu opening as a menu item for where the Desktop folder is.
It may or may not be redundant to create a "New Folder" to select (not open) for the Desktop folder to take over, but it always worked for me using it that way. You might give it a try to see if it may help you. Hopefully it will.
Hell yeah! Service Pack Uno fixed the issue!! Thank you MS.
Thanks Brink for trying to help though.
EDIT: Well, it looks like I was wrong, SP1 did not fix my issues. However, after restarting the system after the update, the issues did not persist. It was not until my next self-initiated restart that the problem resurfaced. This leads me to believe that system updates must have their own unique shutdown protocol. Is there anyway to verify this or perhaps launch such a shutdown?
    HP DV8000
    HP 430180-001
    internal
    internal
    1680 x 1050
    internal
    um...fast?
Your welcome DKqwerty. I'm just glad that your problem is fixed now.
I did everything as described and something really weird happened:
1. I modified the "My Music" folder to E:\newfolder
Now, when I open the My Music folder, it suddenly a new user folder, so I have to user folders. I open my user (Filip) where all the documents, picture, music folder are. When I click on the My Music folder, all of the documents, pictures, hyperlinks folders etc. are also in the Music folder!
What happened and how do I get things back to normal?
Best
Filip
Hi Filip,
It sounds like you accidently moved all these folders into that location somehow.
See if you can do step 5 in Method One to restore each folder's default location. If not, you will need to use Method Two to manually change each folder's location back to the default location in the registry.
