Task Manager - Small Footprint Mode
How to Switch Between Normal and Small Footprint Mode in Vista and Windows 7 Task Manager
This shows you how to switch between the normal and small footprint mode in Task Manager to save window space.
This can sometimes be mistaken as a problem with Task Manager.
1. Open Task Manager by:​
A) Press CTRL+SHIFT+ESC.​
OR
B) Right click on the taskbar and click on Task Manager.​
2. Click on the tab you want to see. (see screenshots below)​
3. Double click on a border of Task Manager to switch between modes.​
NOTE: See the border areas highlighted in yellow below.​
Normal Taskbar Footprint Mode:
Small Taskbar Footprint Mode:
Your welcome vgzm.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thanks Brink, I thought I had some sort of weird virus messin' with my Task Manager. I guess it was only me double clicking the border inadvertently.
    qx6700
    intel badaxe2
    6 Gig Corsair ddr2 800
    Nvidia 9600GT 512
    OB
    BenQ24 Princeton19
    1920X1200 1280X1024
    8 X 500 Gig 3X 1TB RAID 0 and 2X 500 GB
    Rosewill 950
    Thermaltake
    Chilltec
    MS Natural Ergonomic 6000
    Kensington Expert
    DSL
Your welcome Hkancyr. It is definitely easy to think that. :geek:
You're most welcome Ali, and welcome to Vista Forums. :)
