Preview Pane - Enable or Disable
How to Enable or Disable the Preview Pane in Vista
The Preview pane allows you to see a preview of the highlighted image, video, or document file in the opened Windows Explorer window without opening it. This will allow you to Add or Remove Preview Pane from being listed in the Organize -> Layout menu option in a Windows Explorer windows.
This will be applied to all user accounts on the computer.
If you just wanted to turn the Preview Pane on or off, then see:
How to Turn the Preview Pane On or Off in Vista
EXAMPLE: Preview Pane Enabled and Disabled
METHOD ONE
2. In the left pane, click on User Configuration, Administrative Templates, Windows Components, Windows Explorer,​
Explorer Frame Pane. (See screenshot below step 3)​
3. In the right pane, right click on Turn off Preview Pane and click on Properties. (See screenshot below)​
4. To Enable the Preview Pane
A) Dot Disabled or Not Configured and click on OK. (See screenshot below step 5A)​
B) Go to step 6.​
5. To Disable the Preview Pane
A) Dot Enabled and click on OK.​
METHOD TWO
Using a REG File Download
1. To Enable the Preview Pane
Enable_Preview_Pane.reg
download
B) Go to step 3.​
2. To Disable the Preview Pane
Disable_Preview_Pane.reg
download
  • Enable_Preview_Pane.reg
  • Disable_Preview_Pane.reg
