Vista - Previous Versions - Shadow Copy
Comment
Old 01-17-2008
Brink
How to Restore Previous Versions of a File and Folder in Vista
Old 02-08-2009
angyecarm
Vista Ultimate x64
Re: Previous Versions - Shadow Copy
Why haven't I any Previous Versions of files? It doesn't create
Old 02-08-2009
Brink
Hello Angyecarm,
Do you have everything set as per the WARNING box at the top of the tutorial for it's requirements?
Old 02-08-2009
angyecarm
Vista Ultimate x64
Yes I have everything set as in the warning box otherwise I don't ask for help.
I've read on the net that the problem could be have a partition with XP. Can you confirm it?
Old 02-08-2009
Brink
Angyecarm,
If you are dual booting with XP, then yes this could be the cause. Everytime you start XP, the Vista System Restore points and shadow copies get wiped out. This tutorial below will show you how to stop this.
System Restore Points - Stop XP Dual Boot Delete
Afterwards, create a restore point in Vista to help speed up Vista having previous versions available.
Old 10-12-2009
blegs38552
Vista Home Premium 32bit
I am running Win 7 RTM Professional, but everything looks the same.
Everything on my system is set up as you suggest, but when I click on the Previous Versions tab, igt says to there are no previous versions available.
I looked at my Windows backup - there are files for which the previous versions should be out there. I also looked at the System Volume folder, and it it populated by files that are timestamped as the same time as my backups were created.
All services are set as they should be.
Any ideas?
Old 10-12-2009
Brink
Hello Blegs,
All Windows 7 issues need to be posted at out sister site Seven Forums instead. This way this forum can stay on topic with Vista.
PM me there with a link to your post when you get a chance to. I'll be happy to see what I can do to help.
Old 10-12-2009
blegs38552
Quote  Quote: Originally Posted by Brink View Post
Hello Blegs,
I have found an answer in this article which applies to Vista and Win 7:
dreamlayers: In Vista, the "Previous Versions" tab requires administrative shares
Since this applies to both, I am leaving the posting where it is.
Old 10-12-2009
Brink
Blegs,
I'm happy to hear that you found a solution to your problem. Thank you for posting back and sharing it.
Comment
Tutorial Tools
Tutorial Category
help shadow copy and previous version not working. Vista General
Folder Versions has Non Existent List in Previous Versions Tab Vista performance & maintenance
Shadow Copies (Previous versions) of files do not work? Vista General
shadow copy (previous version) Vista General
